Truck will fire, but wont start - Chevy and GMC Duramax Diesel Forum
Old 01-17-2013, 05:30 PM   eBay Motors  #1 (permalink)
DuramaxIsBEAST's Avatar
My truck has starting doing this thing where I will crank it over, it will fire, but wont start. It takes about 4 of these to get it to run. I am thinking maybe glow-plugs, or air in the fuel. I live in Michigan, about 25*F, garage parked. I run the winter fuel additive.
2002 Chevrolet 2500HD LB7 EC/SB LS 4X4
Mods: K&N Air Filter, Bosch Injectors, Extra Leaf Springs, MB Motoring Wheels, Toyo Open Country A/T and Monreo Shocks.
DuramaxIsBEAST is offline   Reply With Quote
Old 01-17-2013, 05:58 PM   eBay Motors  #2 (permalink)
just one day when it it warm, rule out that it isnt the cold. my truck did the same thing, eneded up being an injector returning to much fuel and the truck had to turn over twice as long to build up proper rail pressure to get it running. did the same excat thing as your, had to hold it till it stopped turning over atleast 4 to 5 times
2003 duramax silver birch...ccsb
finally bought it from my dad and had it painted a charcoal color, new injectors, h2 rims, 285-70-17 fierce attitudes, raptor 150, cat filter adapter, edge cs with probe..... 210,000 and climbing
dont know which way to go with it for future
efi live tuning- Kory willis......awesome.
ridergonwild5692 is offline   Reply With Quote
Old 01-17-2013, 06:09 PM   eBay Motors  #3 (permalink)
If you pumped the primer would it fire up?
And how much was that repair?
Old 01-18-2013, 06:35 PM   eBay Motors  #4 (permalink)
Brent@LDS's Avatar
As stated above sounds like you may have some injector issues. It would be on the return side of the Injector. Does your truck start any better if the fuel filter housing is primed.
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-765-1615
Click here For,
LB7 Injector Install Instructions
Brent@LDS is offline   Reply With Quote
Old 01-21-2013, 09:27 AM   eBay Motors  #5 (permalink)
I am almost 100% sure it is the glow-plugs, when it was 45 degrees out yesterday it started right up, but this morning it was 16 degrees, and it did not. I found a guy who while do the plugs for $260, that is parts and labor.
Old 01-21-2013, 09:28 AM   eBay Motors  #6 (permalink)
No difference when primed....
Old 01-21-2013, 09:35 AM   eBay Motors  #7 (permalink)
Cmart1989's Avatar
X2 on Injectors
2006.5 CC/SB LBZ
EFI Live DSP5
PCV Reroute & EGR Blocker Plate
Edge Insight CTS w/ EGT Probe
4" MBRP Exhaust Turbo Back w/ 5" Rolled Tip
Resonater Plug
Transgo Jr.
Pump Rub Fix
High Beam All on Mod
Tie Rod Sleeves
More to Come....!!!
Cmart1989 is offline   Reply With Quote
Old 01-21-2013, 10:18 AM   eBay Motors  #8 (permalink)
It starts fine in warm weather though
Old 01-30-2013, 01:59 PM   eBay Motors  #9 (permalink)
Got new glow plugs, all of them where shot. Every thing is good so far!
Old 01-30-2013, 06:20 PM   eBay Motors  #10 (permalink)
maxedout3's Avatar
Had some problem with my 02. It would fire, but not start. Thought it was my batteries and after that checked out fine i thought it was my pump. Turns out it wasn't that either. I had to prime it to get air out of my fuel lines and then it fired up. I need a Complete duramax Filter head rebuild kit because my seals are shot. The kit just consist of some seals to rebuild the fuel filter head and is a $20 fix. Thought it was due to my programmer but i hadn't been running it hard, just on fuel economy but luckily it wasn't. Hope this helps if you have any other problems with it not starting down the road. These LB7' s are prone to this happening but its not a big deal.
maxedout3 is offline   Reply With Quote
