stumped... white smoke - Chevy and GMC Duramax Diesel Forum
Old 01-25-2013, 09:17 PM   eBay Motors  #1 (permalink)
CamoLB7's Avatar
okay im stumped i have a 2003 Federal LB7 its straight piped and at idle i have the white smoke blowing out i know this is an injector issue them going bad but this is the only simptom that my truck has? It only has 57,000 miles i know im beating a dead horse but i have been reading for months and just dont know
I mean i dont know if this means anything but it did sit at my uncles house for about 4 years with out being started
And one last thing its a LSSV not sure if that has any meaning but does the military run a diffrent blend of diesel on base?
Any help will be great thanks Tanner
CamoLB7 is offline   Reply With Quote
Old 01-25-2013, 09:20 PM   eBay Motors  #2 (permalink)
baconstruction's Avatar
test your balance rates
05 lly cc, afe turbo inlet, blocker plate, efi dsp5 by nick (duramaxtuner.com)
baconstruction is offline   Reply With Quote
Old 01-26-2013, 10:33 AM   eBay Motors  #3 (permalink)
Brent@LDS's Avatar
I would also get your return rates checked if its smoking and has a strong diesel odor from the exhaust?
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-765-1615
Click here For,
LB7 Injector Install Instructions
Brent@LDS is offline   Reply With Quote
Old 01-26-2013, 10:40 AM   eBay Motors  #4 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
It very well could be your injectors. You could have an injector sticking open on the exhaust stroke and it doesnt burn, this causes white/blue smoke. But while driving the heat burns the fuel and that little leak isn't noticable. Try to free it up with additive like Power Service. I used the whole 250ml. bottle in a tank a couple times, then ran the reccomended amount from then on. It might free up that injector.
It's worth a try... But if you do need injectors definately give Brent a call! LDS has great prices and Bosch remans.
-Aaron-
2001 GMC Sierra 2500HD, Limited Edition, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires,
MANY More extras inside...
01 D_Max is online now   Reply With Quote
Old 01-26-2013, 07:37 PM   eBay Motors  #5 (permalink)
PlugItIn's Avatar
Sounds like a bad injector to me, balance rates would let ya know.
PlugItIn is offline   Reply With Quote
