White smoke when cold, Black under Acceleration - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 02-20-2013, 08:47 AM Thread Starter
I'm back. Throwing a glow plug code and when I start the truck up, it starts harder than normal, but starts and runs smooth. It's about 27 degrees outside and when idling it has a white smoke but it dissipates in the air quick. When I put under a little acceleration, it turns coal black and thick. Is this just the cold motor because of the glow plug code. Taking it the shop soon to check the module. Please tell me this is a cold motor issue and not injectors. I just did them like 10k ago. No power issues and runs like a champ. Can the white smoke come from unburnt fuel then turn black as I add more. This would indicate either a cold engine or a boost leak. Turbo is still a little laggyl
03 CrewCab LT, Long bed, Cab high topper, 265/70/17 Michelin LTX MS2 tires, Intake Horn Mod, EFI Live by Idaho Rob, PPE Boost Valve, Stainless Steel brake lines; Trans built by Mike L.
reifwj is offline
post #2 of 7 (permalink) Old 02-20-2013, 08:58 AM
gr8shot's Avatar
The white smoke is probably just steam. The exhaust can make steam just like gassers can. Usually it only does if when its quite a bit colder out. Gassers will do it at like 50* or colder, usually a diesel only does it when its well below freezing. The black smoke though shouldn't happen unless the truck is tuned. In which case it should do it the same every time.
Sent from my DROID RAZR using AutoGuide App
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #3 of 7 (permalink) Old 02-20-2013, 09:11 AM Thread Starter
I did do the intake horn mod when I had it off. Any sensors I need to check while I'm under the hood that could cause beside MAF?
reifwj is offline
post #4 of 7 (permalink) Old 02-20-2013, 09:23 AM Thread Starter
Just cleaned MAF, and still there. Will try taking the air filter off on the way to the shop and see if it clears as it warms. Wasn't doing it when I parked it after the new CP3 a few days ago
reifwj is offline
post #5 of 7 (permalink) Old 02-20-2013, 11:21 AM
gr8shot's Avatar
I wouldn't suggest running any engine you care about without an air filter!
How long did you drive the truck? Did it sound abnormally loud once you got it up to temp?
Jesse
2004 LB7
Tastefully modded
Lots of miles
gr8shot is offline
post #6 of 7 (permalink) Old 02-20-2013, 11:28 AM Thread Starter
No it's quieter after new cp3. Pressurized the system with shop vac after I got the thermostat housing off and no leaks. I know I had oil in my intercooler tube on the driver side. Really afraid my turbo is crapping out.
I thought twice about the air filter. It did smoke less after it warmed up but more than it used to before the new pump. Any sensor I should look at?
reifwj is offline
post #7 of 7 (permalink) Old 02-20-2013, 08:38 PM Thread Starter
Finally got it on the highway. Runs brand new, but when I let off the throttle I can hear what I would say is a lifter on a gasser. It doesn't really seem to speed up or slow down, and it is quiet enough I can not hear it unless I am off the throttle or going up a grade in a higher gear.
reifwj is offline
