Leaking Oil Out Of The Exhaust - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 13 (permalink) Old 02-25-2013, 03:00 PM
sparepartsracing's Avatar
i had a cracked piston but no oil in my exhaust....either way welcome to the motor build club!
Truck: 2004 eclb lb7
Motor: lbz rods, delipped lb7 pistons, arp main and head studs, federal heads, lml manifold, ppe dampner.
Trans: Bt diesel works built trans, ml converter, Bt tapshift
Fuel: 60% injectors, lbz cp3
Air: s476 over stocker
Exhaust: 5" downpipe, 5" exhaust factory exit no tip. Bd manifold. Everything heat wrapped.
Wheels: 20x10 fuel hostages, 35" nitto trail grapplers
Bumpers: roll pan, big Chevy hitch
sparepartsracing is offline
post #12 of 13 (permalink) Old 02-25-2013, 05:55 PM Thread Starter
MAXX IT OUT's Avatar
At first i thought it was just that the aurora 3000 had blown it seals, because there was oil on the intake side of the turbo. I put the S366 on Saturday and it was ran with a light haze at idle, but as I revved it up it started to blow white smoke and leak oil. One of the probes in the up pipe doesn't stay in properly and it was shooting oil out before the turbo. Don't the lb7 have oil cooled pistons, the bottom of the pistons?
2001 Chevy 2500HD Red on black
With stuff done
MAXX IT OUT is offline
post #13 of 13 (permalink) Old 02-28-2013, 02:35 PM Thread Starter
I have has started to pull my engine, where are the best lift point on the engine, or is there already fixed lift points on the engine?
With stuff done
