bleed air out of system? - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 02-23-2013, 09:51 PM Thread Starter
I have a 03 dmax
Changed the injectors, and fuel lines on it and got it all back together and got it fired up today and it ran for like.10seconds and shut off.
Before starting it i primed the filter and pumped thevplunger on the fuel filter prior to starting up. An now i cant seem to getvit.to start again. Im guessing it has air in it.
Any input/help/tips/ideas? Much appreciated
Randy Swanson
RS383 is offline
post #2 of 8 (permalink) Old 02-23-2013, 10:17 PM
Banned
Did you open the bleed screw?
dieselnuts6 is offline
post #3 of 8 (permalink) Old 02-24-2013, 05:30 AM Thread Starter
Yes. After the ;plunger got hard i opened the bleeder next to tge plunger.
Is that the bleeder your talking about?
Just a dumb question. Do i need to have the key on while trying to do this?
RS383 is offline
post #4 of 8 (permalink) Old 02-24-2013, 06:20 AM
StealthBoogie's Avatar
Open the bleed tab on the filter and prime the fuel filter until fuel comes out steadily. Once it flows good close it. Prime filter until it gets hard to push and start the truck. it may shut off one more time. If it does only prime it again till its hard and start her up
Boogie Man's LMM Build Thread
08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake
Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves.....
StealthBoogie is offline
post #5 of 8 (permalink) Old 02-24-2013, 07:14 AM Thread Starter
You mean the tab on the bottom of the fuel filter?
RS383 is offline
post #6 of 8 (permalink) Old 02-24-2013, 08:41 AM
2trout's Avatar
its the small black plastic tab on top of the filter body, use a larger blade screw driver to crack it open, no need to fully remove it, just crack it open and pump away, once fuel starts running out, screw it tight again, hope this helps.
'MONGO' '02 2500HD 4X4 CC/SB
Built transmission - GOS Performance; Suncoast 6 speed conversion
Flex-A-Lite 284 Electric Fans; Mean Green Alternator
4" MBRP Exhaust; MBRP Downpipe; BD Power Exhaust Manifold
BatMoWheel (stock turbo housing), PPE Boost Valve
ProFlow Air Horn; aFe cold air intake
Edge Insight CTS with EAS expansion system, EGT, Boost & Ambient Temp; EFILive via CTS - Idaho Rob
AirDog II DF-165
Firestone Ride Rite air helper springs
Bilstein shockers
2trout is offline
post #7 of 8 (permalink) Old 02-24-2013, 09:15 AM Thread Starter
All air is bled out of system i do beleive..
It stays running now. But has real loud knock, and rough idle.
What the craps the problem now? Im frustrated beyond my limits... lol
RS383 is offline
post #8 of 8 (permalink) Old 02-24-2013, 12:08 PM Thread Starter
Well. Its fixed. My dumb butt didnt plug in the fuel rail sensor.
RS383 is offline
