Blue/ white smoke - Chevy and GMC Duramax Diesel Forum
Old 02-25-2013, 10:40 AM   eBay Motors  #1 (permalink)
emcarthur's Avatar
Blue/ white smoke
Hey guys,
I got my injector balance rate done, and they come back okay. So I'm not sure what's going on with it smoking. I'll start it up to warm and it'll not smoke. But once I start driving it then come to a stop light it starts to smoke. Its look as if its burning oil with some white. I checked my dipstick and it doesn't seem its burning a lot. I couldn't see a CAT under the truck, unless its up by the turbo. So I'm not sure if it has a EGR or not. But any other possibilities what could be causing this? Longer I drive it the more it smokes at stops. Any info would be great!
Thanks.
Sent from my DROID RAZR using AutoGuide.Com Free App
emcarthur is online now   Reply With Quote
Old 02-25-2013, 11:15 AM   eBay Motors  #2 (permalink)
e46_330i's Avatar
How does it idle? Surging at all? And what do you mean by the balance rates were "okay". Do you have them on hand? Did you check them with the truck at operating temperature and in park & drive?
2004.5 Sierra SLT 4WD CCSB Black/Black
ARP Studded, Pro-Fab Deleted, PCV Re-Routed
Alligator FPRV Race Valve
LBZ FPR
LBZ Full Intake & Mouthpiece
Tie Rod Sleeves
20x10 ET -12 Fuel Hostage's & Nitto 420s 305/50/20
All-On Mod W/ HID's in all 3
MA Pump Rub Kit
3" DE Down Pipe to Dump
EFI Live DSP5 By Kory "Supa Tuna" Willis @ PPEI
e46_330i is online now   Reply With Quote
Old 02-25-2013, 11:20 AM   eBay Motors  #3 (permalink)
emcarthur's Avatar
Idles fine, no surging. I do not, that's what the mechanic said at the dealership.
Old 02-25-2013, 11:30 AM   eBay Motors  #4 (permalink)
SickLB7Crenshaw's Avatar
Fill out ur sig.. is it an LB7? and balance rates dont always tell you if they're bad or not.
05' LLY 12.41 @109.9
Blake
SDP Twinz, 40% overs, EFILive, Stage V trans, BT lock up box
4'' Exhaust, Airdog, Traction Bars, Built Front End,
Big Thanks to Dustin, Idaho Rob, and Scott
01' LB7 13.5@97
EFILive, Grade C HG, ARP studs,
4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans
SickLB7Crenshaw is offline   Reply With Quote
Old 02-25-2013, 11:33 AM   eBay Motors  #5 (permalink)
emcarthur's Avatar
Yes, it's a 03 with 186k on the clock. Oh alright. How else to diagnose a injector problem?
Old 02-25-2013, 11:41 AM   eBay Motors  #6 (permalink)
does your oil smell like diesel? pour a whole jug of diesel kleen in her and see if it stops smoking but i would bet its time for new injectors. Lb7s are bad about injectors going bad.
Blake
01' LB7 13.5@97
Old 02-25-2013, 01:30 PM   eBay Motors  #7 (permalink)
emcarthur's Avatar
I can't smell any fuel in it. But I'll try with diesel kleen and see if that helps.
Old 02-25-2013, 03:31 PM   eBay Motors  #8 (permalink)
Brent@LDS's Avatar
Does the smoke from the exhaust have a strong diesel odor?
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-765-1615
Click here For,
LB7 Injector Install Instructions
Brent@LDS is offline   Reply With Quote
Old 02-25-2013, 03:43 PM   eBay Motors  #9 (permalink)
JustBetterInTexas's Avatar
If you put your dipstick fresh from the motor onto a paper towel, you will see an almost rainbow ring spread from the oil into the paper towel IF you have fuel in your oil.
2006 GMC Sierra 2500HD CC/SB D/A 4x4 - PPE Air Box mod, MBRP 3" DP to 4" w/ muffler, EGR blocked, DIY PCV reroute, ADII 165, Michelin LTX A/T2 265/75/16.
Tuned by Rob Coddens
Adrenaline Truck Performance
Duramaxstore.com, Your Duramax Diesel-Only Shopping Resource
JustBetterInTexas is offline   Reply With Quote
