transfer case chain replacement
14K views 9 replies 4 participants last post by  bigskyjimmy
Is it possible to replace the chain in my transfer case Without removing the whole transfer case from my truck????:trying to take the easy way out:help
#4 ·
Im not quite sure you can get the case split in half on the truck. Not sure how accessible the internal snap ring is on the truck
If you can remove the body it's doable in the truck :p
The rear case snap ring is on the top of the rear half of the case, can't get to it with the case still installed. Also, even if you were able to find a way to get that off, the torsion bar crossmember is in the way also and would have to be removed. Much easier to remove the transfer case.
