Belt Tensioner Pulley? - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 05-04-2013, 11:09 AM Thread Starter
The pulley on my tensioner is getting a little wore out, shaking pretty rapidly when the trucks started. I ordered a new pulley off of amazon, that it would work as either a tensioner or idler pulley. It was noticably bigger then the pulley that was on it, and was to tight of a fit. Does anyone know where I can get one? I called chevy and they dont sell it seperatey from the tensioner
The pulley i ordered
http://www.amazon.com/Goodyear-49006-Gatorback-Tensioner-Pulley/dp/B000C30J7O/ref=sr_1_1?s=automotive&ie=UTF8&qid=1367690575&sr=1-1&keywords=Goodyear+49006
jeckel7234 is offline
post #2 of 21 (permalink) Old 05-04-2013, 01:35 PM
Earnhardtfan's Avatar
How old is the tensioner? For another $30 you can get the whole assembly off Amazon. Might be worth the extra $$$.
Justin 2001 LB7 Silverado 2500HD LT CCSB 4x4.
EFI Live by Idaho Rob, 447K+ and rolling, Undercover Bed Cover, Vortex spray in bed liner, Odyssey Extreme Batteries, Westin steps, Bilstein Shocks, Road Master Active Suspension, M/A Pump Rub Kit, PPE Trans Cooler, MBRP 5" Exhaust, Edge Insight CTS, K&N drop in filter, AirDog II 100 w/ CAT 751, LLY FF Housing w/ Racor, Running on LMM Blacked out Wheels & Michelin LTX M/S2 tires.
ADRENALINE TRUCK PERFORMANCE
Lincoln Diesel Specialties
Merchant Automotive
Earnhardtfan is offline
post #3 of 21 (permalink) Old 05-04-2013, 02:35 PM
Administrator
jc1843's Avatar
Be sure you replace the idler pulleys-- those usually wear out before the tensioner. If any of the pulleys get bad enough, the fan belt will come off, and you will loose power steering, power brakes, and radiator cooling fan.
jc1843 is offline
post #4 of 21 (permalink) Old 05-04-2013, 04:27 PM
You can buy just the tensioner pulley from Rock Auto for $13.23 (part number 36239). It's a different part than the idler pulley. The retaining bolt is a different size, too. Replacement is real easy. I also replaced the ider pulleys. RockAuto sells those, too, for $21.79 each (part number 36310).
If you want to replace the entire tensioner assembly, Rock Auto sells them. Prices range from $39 to $86.
Wherever you get the pulleys from, make sure you get the STEEL and not the PLASTIC ones.
2003 2500HD Duramax CC LongBed 4x4
BFG KO2 245/75R16
262K+ miles on the stock injectors.
Fab Four Elite Bumper Replacement
Precision Billet Torque Converter
DSB'd: 2000 F250 Powerstroke ExtendedCab Shorty 4x4.
jblather is offline
post #5 of 21 (permalink) Old 05-04-2013, 05:19 PM
mackthehack's Avatar
mrmanners can set you up.
sas'd lbz with stuff
mackthehack is offline
post #6 of 21 (permalink) Old 05-04-2013, 06:13 PM Thread Starter
I just got the truck about 2 weeks ago, its an 01 2500hd with 133k, the tensioner doesnt look to bad though and has plenty of spring force on it, thats why id really like to save the money. I checked both of my idler pulleys when I had the belt off and they both were good to go.
post #7 of 21 (permalink) Old 05-04-2013, 07:34 PM Thread Starter
I looked up the part # you gave, and that one has groves through it? ANd mine doesnt. Thanks for all the other info though
post #8 of 21 (permalink) Old 05-04-2013, 07:35 PM Thread Starter
and sorry im new here/the whole diesel world, what the hell is a mrmanners?
post #9 of 21 (permalink) Old 05-04-2013, 07:58 PM
LHN...We ARE the Joneses
Originally Posted by jeckel7234 View Post
....and that one has groves through it? ANd mine doesnt.
Tensioner pulley has grooves, idlers are smooth.
The user name for one of our site vendors.
Synthetic Motorsports - Chevy and GMC Duramax Diesel Forum
Hook'em_Horns! is online now
post #10 of 21 (permalink) Old 05-04-2013, 08:18 PM
From personal experience with another vehicle, a good preventive maintenance measure is to replace both the tensioner and the idler especially with the kind of milage on that rig. When one of them fails it can be costly and it is preventable. Just my 2 cents or me trying to save 2 cents and spending $1500 after the fact.
Current Truck: 2016 GMC Sierra Denali Duramax Z71. every option with exception of rear seat video. Snugtop truck cap with keyless entry, Edge Insight CTS II, custom rear back up camera for my boat trailer with quick disconnects.
Former Truck:2012 GMC Sierra SLT 2500 HD Crewcab, Duramax, Z-71 (4x4),Bilstein Steering Stabilizer, EGR fender flares, Century cap with interior carpet, BedRug, S & B cold air intake, stainless nerf bars, Banks DPF back Monster Exhaust, GM Under rear seat box, Edge
idamainer is offline
