Coolant Leak - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 32 (permalink) Old 06-20-2013, 08:16 PM
OregonDMAX's Avatar
mine looks like its coming from the headgasket area too but its on the driver side, i cant figure it out its only leaking though not burning any coolant
02 CCSB 4x4
Mike L trans, Magnaflow 5" straight pipe, Magnaflow 3" DP, AEM CAI, EFILive by Idaho Rob, ADII 165, BT lockup box, CTS Insight, boost increase valve, RDL intake horn, manifolds/uppipes, 3" MBRP boost tubes, port/polished/wetzel wheel turbo by Yellowchevy, turbo blanket, Rareparts HD tierods, Allseason brace, 3/5 drop, 60" traction bars, MA pumprub fix, Alligator trans cooler lines. Russell stainless brake lines, LML 20's/420's
OregonDMAX is offline
post #12 of 32 (permalink) Old 06-21-2013, 03:09 PM
Yeah mines the same just on the passenger side. I was kinda stumped when I topped off the coolant and it just started pouring out on the floor, if the head gasket leaked that bad it would really run like crap, lol, and it runs great, with the new injectors and all. I actually went through the whole entire fuel system from the tank up. Glad to find out it's probly not the head gasket, havent checked that plate yet but will.
2001 GMC Sierra 2500HD crew cab LB7/Allison , 188,xxx miles, leveling kit w/33's, 4'' straight pipe with 7'' miter tip, cut air box, nicktane fuel filter adapter, New Injectors!, more to come
chevysnchainsaws is offline
post #13 of 32 (permalink) Old 06-21-2013, 03:16 PM
CFD95's Avatar
Check the heater hose quick connect fittings that go to heater core thru firewall
2007 GMC 2500 LBZ CLASSIC CCSB
EGR BLOCKED AND STICKED
MAGNAFLOW DOWN PIPE
MBRP 4'' EXHAUST
BILSTEIN SHOCKS
Air Dog 2 165
CFD95 is offline
post #14 of 32 (permalink) Old 06-21-2013, 04:13 PM
Ok..I have a leak too. Just looked and found the hose on drivers side lower part of engine leaking. not sure if its at the hose clamp or the hose or something else. going to investigate further when things cool down. There is a gooseneck/90 degree metal adapter comming off the engine on the drivers side, low on the engine. The hose goes about 1 foot then there is molded tee with a small maybe 1/2 inch tap line. the larger maybe 2" continues across the front of the truck to somewhere, again tracing out after it cools.
Any input in the meanwhile would be appreciated. not a lot of fluid just enough to leak and leave a puddle.
keith gigabyte is offline
post #15 of 32 (permalink) Old 06-21-2013, 04:14 PM
oh yea its an 01 lb7 engine
post #16 of 32 (permalink) Old 06-21-2013, 04:50 PM
tripleturbo's Avatar
Mine was leaking back side passenger block and I got it pressure tested and it was my heater pipe or whatever you call it lol I thought it was head gaskets to.
06 lbz cclb
tripleturbo is offline
post #17 of 32 (permalink) Old 06-21-2013, 05:31 PM
I think my heater hoses were good, I'll double check though. It just leaked all over with no pressure though, it wasnt running and it just dribbled out all over the floor into a big puddle, runs right down the bellhousing and off the back of the head, passenger side. I ordered the gasket for that plate, hard part to find! Merchant Automotive has it, the dealer here couldnt even figure it out, I had to give them an item number and schematic number so they could look up the gasket
post #18 of 32 (permalink) Old 06-21-2013, 06:54 PM
lookin at some views on net..that may be my water pump..Always worked on gas engines so pump was in middle of engine driven by belt. looks like the diesel doesn't have external belt..any input guys?
post #19 of 32 (permalink) Old 06-21-2013, 07:14 PM
Thats where mine was leaking lol one guy said Head gasket but I didnt have any signs of head gaskets.
06 lbz cclb
post #20 of 32 (permalink) Old 07-02-2013, 10:43 AM
Ya play hard Ya pay hard
DieselDog05's Avatar
OP , did you ever resolve your leak?
2014 Silverado CCSB
Airdog 165 4G
EFI by Kory Willis
PPE Downpipe
Flo Pro 4" Single exhaust
XDP EGR Delete
S&B Intake
Insight CTS2
DRP PCV Reroute
DieselDog05 is offline
