| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 01-04.5 LB7 Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  | |
07-12-2005, 10:18 PM
eBay Motors
#1 (permalink)
| | Administrator / Web Servant
| Is your Truck an LB7 or an LLY? Ok,
In 2004 GM upgraded the Duramax engine half way through. The change was drastic enough that performance parts such as Intakes and PCM mods for the newer 2004's do not work.
So, how do you know if you have an early 2004(which is called the LB7) or the later 2004 (called the LLY)? Check your vin number. If the 8th digit of your VIN number is a 1, then it is an LB7 Duramax(the early one). If the 8th digit is a 2, then it is an LLY(later 04.5).
Hope this helps! |
| Advertisement
09-16-2005, 02:37 PM
eBay Motors
#2 (permalink)
| | Junior Member
| Lb7 My truck is an LB7. It is a 2002. |
09-23-2006, 06:41 AM
eBay Motors
#3 (permalink)
| | Gear Jammer...
| Hers an up dated list of vin #'s and engines to include the 06 lly and the lbz,
8th Vin #1-LB7 300 hp
8th Vin #2-04.5-05 LLY 310hp autos only, 300 hp manual trans and 4500/5500
8th Vin #3-06 LLY ratings are the same as vin 2
8th vin #D-LBZ 360 hp auto only, not an option in manual trans or 4500/5500 trucks>
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
11-04-2006, 07:34 PM
eBay Motors
#4 (permalink)
| | DuramaxForum Fanatic
| I love my liLLY
__________________ David Cobb - Dynoed 9-23-06 426/798
2004.5 (thats right a liLLY) Chevy HD2500 4x4 4dr LWB LT3
If guns kill people I should blame mis-spelled words on my keyboard. http://www..com/registe...referrerid=634 |
01-19-2007, 06:04 PM
eBay Motors
#5 (permalink)
| | Junior Member
| So what is the biggest difference between LBY & LLY ?
__________________ 2004 2500 CC
2006 VW Jetta TDI
If you can't stand behind our troops....Feel free to stand in front of them! |
01-19-2007, 08:10 PM
eBay Motors
#6 (permalink)
| | Super Moderator
| Injector design...LLY they are a lot easier to change. The turbo is different too. LLY has a Variable Vane Turbo and LB7 has a fixed vane turbo. The LLY was the first to have a cat converter on Federal emissions too.
4" turbo back MBRP exhaust
AFE Magnum Force Stage 2 Proguard 7 intake Kennedy Diesel Merchant Automotive My Photos |
01-23-2007, 02:57 PM
eBay Motors
#7 (permalink)
| | Junior Member
| Does the LB7 not have a cat converter on it?
2006 VW Jetta TDI
03-07-2007, 10:31 AM
eBay Motors
#8 (permalink)
| | Junior Member
| Quote:
Originally Posted by Chevrolisle Does the LB7 not have a cat converter on it? | No cat on my 02 LB7! |
03-07-2007, 05:12 PM
eBay Motors
#9 (permalink)
| | Super Moderator
| Some did, california emissions LB7s did come with a cat on them. I don't know if that started before 03 or not. Just crawl under there and see if you have one.
12-11-2007, 07:20 AM
eBay Motors
#10 (permalink)
| | Junior Member
| I have a 02 LB7 with 6sp manual trans with 168k and I can't seam to tow a heavy load without it slowing me down considerably when I drive up a slight incline. I don't have a cat and I cut my muffler off and I have a hypertech programmer but I only have it on the 50hp setting for towing. Is there anything else that I can do to get some help out of it, besides a cold air intake?
__________________ 2002 6.6 LB7, manual 6, 4x4, crew cab, long box |
| Advertisement
