Originally Posted by Toypuller Hey I just wanted to put a bug in everyones ears that have lb7's and the stock factory injectors still. I can see that some dont know. Alot of 01-04.5 lb7 (8th digit vin #1) Have problems filling the crankcase with diesel fuel. Or smoking horribly on startup. Typically this means it needs injectors. Some trucks have hard delayed starting, meaning that an injector is bleeding down overnight. They have a special policy replacement warrenty, they are covered for 7 years or 200,000k. A lot of trucks are right about out of factory warrenty. IF YOU DONT KNOW IF YOUR INJECTORS HAVE ALREADY BEEN REPLACED OR WANT TO KNOW WHEN YOUR TRUCK WILL BE OUT OF WARRENTY, POST A VIN CHECK IN THE VIN CHECK FORUM SO WE CAN TELL YOU. If you have already had Dont wait to go in their and tell them your crankcase was/is full of diesel. After the 7 years you could be on your own. |
I was looking at my Vin check history and noticed that i had an "injector replacement" how can you tell from this whether or not all the injectors were replaced?
R.O Date R.O Number Type Labor Operation Odometer Reading
03/11/2008 589512 # J7709 - SERVICE KIT, REVISED 90 DEGREE INJECTOR HARNESS CONNECTORS 43118 miles
03/22/2007 426380 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 23677 miles
01/16/2007 422385 # B5831 - LATCH, TAILGATE/ENDGATE - LEFT - R&R OR REPLACE 23677 miles
01/16/2007 422385 # E7231 - STEERING COLUMN LOWER TRIM COVER REPLACEMENT 23677 miles
12/29/2006 421445 # J5917 - SENSOR, FUEL RAIL PRESSURE (DIESEL) - REPLACE 23325 miles
12/29/2006 421445 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 23325 miles
12/29/2006 421445 # L0748 - FILTER ASSEMBLY, FUEL (DIESEL) - REPLACE 23325 miles
12/26/2006 421233 # J5955 - PUMP, FUEL INJECTION (DIESEL) - REPLACE 23294 miles
12/26/2006 421233 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 23294 miles
12/26/2006 421233 # T2020 - TOWING 23294 miles
12/26/2006 421233 # J5650 - FUEL INJECTOR REPLACEMENT 23294 miles
12/21/2006 421052 # B1784 - WINDSHIELD WIPER ARM REPLACEMENT 23215 miles
12/21/2006 421052 # E7960 - IDLER ARM REPLACEMENT 23215 miles
09/18/2006 415379 # J5420 - FILTER, FUEL ELEMENT - REPLACE 17568 miles
09/18/2006 415379 # T2020 - TOWING 17568 miles
05/23/2005 186093 I Z6999 - PDI RELATED FLUID ADDS 4 miles
05/13/2005 A50020 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
-2005 Chevrolet 2500 HD D-MAX CC/SB
"...no honey thats not new, it came with that from the dealership..."
-2007 GMC Denali
Stock (Wife wont let me "tweak" it)
"Dude, it takes like 17 Toyota Hybrids to offset your carbon footprint...That's Cool! Bring on the black cloud of death!"
quoted from my Bro-in-law DC on his first ride in a tuned D-Max
