Hey I just wanted to put a bug in everyones ears that have lb7's and the stock factory injectors still. I can see that some dont know. Alot of 01-04.5 lb7 (8th digit vin #1) Have problems filling the crankcase with diesel fuel. Or smoking horribly on startup. Typically this means it needs injectors. Some trucks have hard delayed starting, meaning that an injector is bleeding down overnight. They have a special policy replacement warrenty, they are covered for 7 years or 200,000k. A lot of trucks are right about out of factory warrenty. IF YOU DONT KNOW IF YOUR INJECTORS HAVE ALREADY BEEN REPLACED OR WANT TO KNOW WHEN YOUR TRUCK WILL BE OUT OF WARRENTY, POST A VIN CHECK IN THE VIN CHECK FORUM SO WE CAN TELL YOU. If you have already had Dont wait to go in their and tell them your crankcase was/is full of diesel. After the 7 years you could be on your own.
__________________ 2005 LT 3500HD CCLB SRW LLY EFI LIVE TUNED BY IDAHOROB TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
They redesigned them so they dont go bad. Its a 3200-3600 job is what we charge gm to do it. I just dont want anyone stuck with that bill.
Torsion lift keys
MBRP 4" turbo back
__________________ 2006 gmc slt,full bore exhaust maniflod,leather,dee zee nerf bars,Diamondback hd tonneu cover,cloud rider mud flaps ,trans go jr with bd valve body, cognito level installed uca , ppe tie rod sleeves,atx teflon,pro comp shocks edge evoloution A/T.295/70/17 nitto terra grapplers: NOW WHERE ARE THE CANADIAN TRANNY BUILDERS
So how do you tell the new injectors from the old? I think I heard that the new ones have a green or white mark on the top if them? I was quoted by the dealer $4900 or so for the whole job.
__________________ 2002 GMC LB7
They're not as bad as the LB7's but they do still go bad. I just put 3 in an 06 LBZ today, so they're not bulletproof.
__________________ Garrett Powermax 3788R dual ball bearing LB7 turbo for sale. The turbo has about 20k on it and is in perfect condition. It comes with the entire mounting kit and even installation instructions. You can get more info at Xtreme Diesel Performance - XDP Diesel Power Performance Parts
Part # GA766172-0001. I would like to get $1500 for everything. This turbo is great for towing!
so how can we go about putting beter injectors in??why are they som exspensive to install
Customer pay it almost 5k for injectors. If you have already had your truck in under warrenty and they replaced the injectors, Most likley they are the updated ones.
Torsion lift keys
MBRP 4" turbo back
