Question on bleeding cooling system - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 06-01-2009, 08:54 PM Thread Starter
motox92's Avatar
When bleeding the cooling system through the bleed screw should the engine be running or not?
2001 Silverado.
motox92 is offline
post #2 of 11 (permalink) Old 06-02-2009, 01:59 PM
DuraTitus's Avatar
I have the same Question, also where is the bleed screw??
DuraTitus is offline
post #3 of 11 (permalink) Old 06-02-2009, 08:09 PM
Tow Master's Avatar
Yes it should be running. Let it run till its warm then slowly open the screw. When water comes out leave water come out for 15 seconds and you should be good (you wont need to totaly remove the screw)
Jason
Tow Master is offline
post #4 of 11 (permalink) Old 06-02-2009, 08:42 PM
yep yep...
WVRigRat08's Avatar
i never had mine running to bleed it dont think i can with bad head gaskets though
05' Chevy LT Black on Black LLY CC/SB Blackout Performance built motor/trans/tuned- Gone
"The Blessed Hellride"-08' GMC Sierra SLT Z71 CC/SB White
Big Dipper Reger proof trans, some sissy tunes, 35's and old school built front end
Done with it
WVRigRat08 is offline
post #5 of 11 (permalink) Old 06-02-2009, 08:45 PM
Ridin'GMC's Avatar
It will never bleed out the air with bad head gaskets. Besides, its bad enough to try it, you can cause the bubbles to collapse against each other and quickly damage the head gaskets. Its called cavitation erosion.
06 LLY CCSB
Just another white truck on the site
Stock engine and trans.
Ridin'GMC is offline
post #6 of 11 (permalink) Old 06-02-2009, 08:50 PM
yep yep...
WVRigRat08's Avatar
i didnt figure you could, i got to get that thing fixed its killin me
Done with it
post #7 of 11 (permalink) Old 06-02-2009, 08:52 PM
Ridin'GMC's Avatar
Get it fixed soon as possible. Some people never get it fixed, and it resulted in an expensive repair.
06 LLY CCSB
post #8 of 11 (permalink) Old 06-02-2009, 08:58 PM
yep yep...
WVRigRat08's Avatar
i was going to just replace the motor but now that i got a rig beater im just gonna do heads, gaskets, and studs if thats all it needs i dont drive it now.
Done with it
post #9 of 11 (permalink) Old 06-02-2009, 09:00 PM
Iceman56's Avatar
Where is this bleed screw?? I just drained my overflow tank and now trying to get it all back in. Do I need to bleed it
White 11 Denali LML CCSB
20X9 BMF Novakanes 285 BFG's
Iceman56 is offline
post #10 of 11 (permalink) Old 06-02-2009, 09:04 PM
Ridin'GMC's Avatar
You don't really have to. Most techs just bleed it if the radiator has been drained. I do bleed it if the radiator has been drained but if it's the overflow, I don't even bother to.
06 LLY CCSB
