2002 Duramax fuel filter primer - Chevy and GMC Duramax Diesel Forum
post #1 of 26 (permalink) Old 09-29-2007, 09:38 AM Thread Starter
I just changed fuel filters and was pumping up the system with the little plunger on top of the filter housing when I noticed fuel running out from the base of the plunger pump. I removed the 3 screws that hold the plunger in place. Then remover the pump assembly. Inside there is 2 O-ring type seals the top one was damaged. Apparently one seal alone is letting fuel past it. If fuel can get past it then also air.
My question is where is there a source for buying new seal, O-rings whatever you want to call them?
If possible please also reply to me direct
mikesaero@ubtanet.com
mikesaero is offline
post #2 of 26 (permalink) Old 09-29-2007, 11:30 PM
Administrator
ob_1jr's Avatar
Your best bet would be to match it up with one at the autoparts store. GM won't just sell you the o-ring. You need to buy the whole filter head assembly from them and it runs about $600.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #3 of 26 (permalink) Old 09-30-2007, 07:18 PM Thread Starter
O-rings primer pump
Wow, thats not good news. GM is bound to have some un-happy customers if some substitutions can't be found! I checked a few auto parts houses Saturday and found nothing that was similiar. Hopefully Monday I can try some of the big truck service centers.
Thanks for the feedback... Mike
post #4 of 26 (permalink) Old 09-30-2007, 07:36 PM
Check with NAPA, they should pull out a big box/assortment, pick through them until you find a match, might be metric.
gunny is offline
post #5 of 26 (permalink) Old 09-30-2007, 10:08 PM Thread Starter
Thanks Gunny
These o-ring looking seals are actually a springless hydraulic lip seal. 10 out of 10 auto parts places didn't have anything close. The GM dealerships are very willing to help but have no breakdown of parts. They have the whole fuel filter housing ($610.00) as ob_1jr. pointed out. The dealership was willing to knock off a hundred bucks but I don't want the extra work of changing out all the hoses to the new housing and it seems sick and wrong to rob one or two seals out of a 5 or 6 hundred dollar unit.
I went to a Wheeler Caterpillar dealership today and his supplier has a few of the seals in stock. I ordered a FEW extra, Next Day Air UPS. Hopefully they will work! The seals are supposed to be here tomorrow, so on the bicycle one more day.
Thanks mike
post #6 of 26 (permalink) Old 10-02-2007, 03:47 PM Thread Starter
Thumbs up Duramax primer seals
I found a reasonable replacement seal for the little primer pump. Sure beats 5 to 6 hundred bucks for a new filter assembly!
I ordered a few extra if anyone has trouble with the old seals. You can contact me through the forum or direct.
mikesaero@ubtanet.com (I'm no expert on the automotive end but contact us for complete service, specializing in recovering of fabric aircraft)
post #7 of 26 (permalink) Old 10-30-2007, 03:24 PM
doc5339's Avatar
I just ordered four NU15-1.18 (1 3/16" x 1 1/2" x 5/32") BUNA 80A "Round Rubber Lip Seals" from Hydrapak after talking with Mike last night.
I ordered from George (george@hydrapakseals.com) HydraPak Seals: Your source for o-rings, gaskets, machined seals, polyseals, sheet goods, custom kits and more
Thanks Mike.
doc5339 is offline
post #8 of 26 (permalink) Old 10-30-2007, 03:50 PM
doc5339's Avatar
Do any of you know what the part # is for the metal bleeder screw for the priming pump?
R/
Jake
doc5339 is offline
post #9 of 26 (permalink) Old 10-30-2007, 08:41 PM
Administrator
ob_1jr's Avatar
no, but I believe kennedydiesel.com or gmdieseltech.com has them in stock.
X-pel clear bra
ob_1jr is offline
post #10 of 26 (permalink) Old 04-07-2008, 09:41 AM
Red face Duramax Primer Pump Orings
I have had many calls regarding the orings for the primer pump I can get these orings the only problem is i either need sample o-rings sent to me ot possible get some one to get me the Inner and outer diameter of the oring, if possible to take the groove depth and width of where the Oring goes I see that the thickness of the o-ring was sent to me but I need a sample if someone can get me one I know I hae repalcements for these orings. So if anyone can get back to me as soon as they can so I can help you out. You can reach me at george@hydrapakseals or call 1-800-669-9638 HYDRAPAKS SEALS INC.
Mugz is offline
