EGR cooler - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 12-02-2013, 05:48 PM Thread Starter
EGR cooler
I took the EGR off because I'm about to change injectors. The EGR is full if soot and I'm wanting to clean it.
Any recommendations on how to clean it?
joeysworld is offline
post #2 of 7 (permalink) Old 12-02-2013, 06:40 PM
DURAMAXD219's Avatar
This is posted in the LB7 section so I assume you have a Cali emissions lb7?
Just delete it.
Dylan - LB7
Billet 472 - Dual Fuelers - 45overs - Built Trans
HSP - PPE - LDS - Inglewood
Sponsored by OPDT, Thanks Josh
12.68 @ 110.7
6850lbs
DURAMAXD219 is offline
post #3 of 7 (permalink) Old 12-02-2013, 09:04 PM Thread Starter
Yes, I am from California. As much as I would like to, and after all the trouble I went through to remove the EGR, I would live to delete it. But here in California, we do have emissions test's here. So, no, I'm not going to delete the EGR. Ok, I will take that little booger over to the radiator shop or machine shop tomorrow and have it cleaned.
post #4 of 7 (permalink) Old 12-02-2013, 09:07 PM
rparlee's Avatar
Brake cleaner and a stiff bristle brush?
Ryan
2006 GMC Sierra 3500 SLT CCLB 4x4
Mods: EGR block, EFI LIVE by Rob (DSP5), Edge Insight CTS2 w/ backup cam and EGT probe, Pacer 07.5+ smoked cab lights, M-A Pump rub fix, TransGo Jr w/ Mike L springs, Russell stainless brake lines.
My Build Thread
rparlee is offline
post #5 of 7 (permalink) Old 12-02-2013, 10:09 PM
There,wolf...There,castle
werewolf's Avatar
Lots and lots of brake cleaner. And make sure you clean it over something you don't care about. We dumped ours in some gravel in the driveway over a year ago. It's still stained
2006 2500HD GMC Sierra SB/CC
EFI by kory thanks to Willie at Synthetic Motorsports
Diamond eye down pipe,5" MBRP straight pipe exhaust
PCV reroute EGR delete
Nicktane Adapter W/ Donaldson filter
PPE Race Fuel Valve Ported Fuel Rail Fitting
FASS 150 Titanium
werewolf is offline
post #6 of 7 (permalink) Old 12-03-2013, 03:31 PM
I'm from California and I just put a blocker plate in. As far as I've been told smog is mainly visual.
2003 Chevrolet Silverado 2500HD 6.6L LB7 4x4 CCLB -ARP Studs - Merchant Pump Rub Fix- 4' Cat Back MBRP Exhaust - 3" MBRP Downpipe - Airdog 150 - PPE Boost Valve - Banks Ram Air Intake - 4-6" Cognito NTBD - Rare Parts Gen-II Heavy Duty Tie Rods - PPE Stage 4 Transmission - Batmowheel -
crowellalex is offline
post #7 of 7 (permalink) Old 12-03-2013, 06:20 PM Thread Starter
The EGR was virtually plugged. I have to guess that with all that soot in the cooler, that's partially why I my truck would smoke heavily. Anyway, I took the cooler to the radiator shop to have it hot tanked. Let me stand corrected on California and emissions test. There are areas of California that do not require bi annual testing. There is a visual and they also look at the tailpipe after a rev and a count of 3 to determine if the diesel smokes too much.
