Need to change coolant - Chevy and GMC Duramax Diesel Forum
Old 08-23-2009, 01:34 PM   eBay Motors  #1 (permalink)
strokethis03's Avatar
My DIC says coolant low so im just going to flush it since it has 99k on it and idk when it was changed last. What do i do to change it? Just pull upper and lower rad hose and let her drain out? Then how much dec cool do i put back in?
SOLD
TRUCK: 2003 Silverado 2500HD, Ext Cab, Short Bed
TUNER:Quadzilla On 90Hp
EXHAUST:4 Inch Straight Pipe,
INTAKE:K&N CAI With Amsoil Filter And Intake Horn Mod
WHEELS:18 Inch Ultra 248 (Black)
TIRES:285/65/18 Nitto Terra Grapplers
EXTERIOR:Blacked Out Bumpers and Black Diamond Plate Tool Box With Black Bow Tie, Black Nerf Bars. 06 Style Tow Mirrors, De-Badged
SOLD
2006 Chrysler 300c Hemi STOCK!!!!
strokethis03 is offline   Reply With Quote
Old 08-23-2009, 01:46 PM   eBay Motors  #2 (permalink)
Banned
I know the lb7's have a petcock on the passenger side of the radiator on the bottom. loosen that, pull lower rad hose, loosen coolant tank. once it stops id fill it with distilled water, and drain again.
Old 08-23-2009, 01:58 PM   eBay Motors  #3 (permalink)
is it on the very bottom of the radiator to the right of the lower radiator hose?
how much do you think it will take to fill? and what do you use to keep it from going every where? especially the top rad hose?
SOLD
SOLD
Old 08-23-2009, 01:59 PM   eBay Motors  #4 (permalink)
or do i not pull upper hose?
SOLD
SOLD
Old 08-23-2009, 03:01 PM   eBay Motors  #5 (permalink)
K9Duramax's Avatar
shouldn't need to pull the top hose....
'05 CC/SB, AMSOIL 15w-40 (From Synthetic Motorsports), Cold Air Intake with a dry Nanofiber filter from AMSOIL, PPE Tuner level 1, EGR blocked, LBZ MP, lost KITTY, finished off the rest with 4" SS Magnaflow, Amsoil Torque Drive, 5K HID's, General Grabbers 265 :rockin
K9Duramax is offline   Reply With Quote
Old 08-23-2009, 03:12 PM   eBay Motors  #6 (permalink)
Banned
it will be about 3-4 gallons that will come out of the petcock.
Old 08-24-2009, 11:17 AM   eBay Motors  #7 (permalink)
1953drtelco's Avatar
Have you thought of using EVANS waterless coolant? Boiling temp is over 300 degress....
2005 HD2500 Silverado 2WD EC LB (FE9 - Federal Emissions) 91K miles Goodyear Wranglers 265/70R/17,
LBZ mouthpiece upgrade, BD Exhaust, MBRP DP, Banks Ram-Air with SuperScoop ,4" SS Corsa Exhaust System w/gutted kitty, Amsoil Dual Oil Bypass Filtration, Aux Radiator (Engineer 837) installed, Firestone Air Bags, Allison extra capacity Tranny pan, MagHytec Rear Diff Cover, Synthetic Fluids ...Mike L tranny cooler) 2008 Towing Mirrors with Leveling MOD, PCV reroute, Fumoto Valve, Mad Jacks fuel fiter access door. Running 2% BioDiesel with Optilube XPD,TTS dual lift pumps with Nictane Aux Fuel Filtration. EFI (Tuned ECM from Duramaxtuner) Edge Insight CTS to control the tunes
And the best part of all, no payments and title in hand
1953drtelco is offline   Reply With Quote
Old 08-24-2009, 11:35 AM   eBay Motors  #8 (permalink)
mijdirtyjeep's Avatar
Also when you fill it there is a bleeder bolt on top of the thermostat housing. Pull it out while you fill it, and when fluid starts running out without any bubbles, close it and top off the system.
Jim
mijdirtyjeep is offline   Reply With Quote
Old 08-25-2009, 12:07 AM   eBay Motors  #9 (permalink)
Tow Master's Avatar
If it where me I would remove the upper and lower rad hose as well as the thermostat and drain the coolant. Then run water through the radiator and engine block. Then reinstall upper and lower rad hose as well as thermostat (might want to get new one) and fill with water. Start motor and let it run till thermostat opens than drain. Refill with coolant and your good to go!
That dexcool starts to gum up over time so its good to get it all out of the motor. If you do all that I would switch to the green stuff. That is alot better and wont give you any problems.
Jason
Exterior: Escalade Handles, Front windows tinted to match the rear, painted bumpers & mirrors, billet grille, 285/70/17 Nitto Crossteks on Pro Comp Wheels, Cognito Braces, Stainless Sleeves, Train Horns
Interior: 4 Kicker 10in Subs in 2 custom box's, Autometer Ultra lite II Pyro and Boost gauges, Aeroforce Interceptor Gauge, HID Lows & Fogs, Painted accents
Old 08-25-2009, 04:20 AM   eBay Motors  #10 (permalink)
LHN...We ARE the Joneses
Problems with Green?
None....just as long as you're back at it to flush and fill every 25-30k miles, and have absolutely no Dex left in the system to mix with it. All water based coolants will break down and have detrimental effects on internal components if left unchecked. Green has it’s corrosive properties also.
Draining 1/3 to 1/2 of the system's total 6 gallons, filling with water, running up to operating temperature, and draining again, then topping off with fresh coolant will not achieve complete replacement of coolant. You also won’t have the proper 50/50 mix.
It will however be far better than the toasted 90k mile fluid that was there before. Dropping the lower hose and pulling both engine block coolant drain plugs, flushing the system, and replacing with the proper level (6-gallons) of 50/50 mix will provide a complete service of the system.
AND, if you decide to change coolant types, this procedure will give you no problems with interaction between incompatible coolants mixed together, with 'Evans' being the exception (no water used in flushing).
