Old 11-06-2009, 06:27 PM   eBay Motors   #11 (permalink)
woodbw
06 LBZ 30000 miles just had the same knocking noise, 1 bad injector found. 15 days out of warranty
woodbw is offline   Reply With Quote
Old 11-06-2009, 11:01 PM   eBay Motors   #12 (permalink)
Cowboys2233
Cowboys2233's Avatar
how did you know it was an injector? other than the knocking what will they do. how loud was the knocking. did you lose any power?
Cowboys2233 is offline   Reply With Quote
Old 11-07-2009, 09:56 AM   eBay Motors   #13 (permalink)
woodbw
Unhappy How did I know
Just pulled out on the highway and was coming up to speed, trany started down shifting then the knocking noise started. Loud enough to hear over stereo. Power was way down.
No reduced power or check engine light so I thought it broke a rod. Dealer is one that said it was an injector.
If you have this happen stop and have the truck towed to the dealer. A dead injector will cause considerable cylinder wear, the diesel fuel acts as a lube for the cylinder walls.
