Old 10-13-2009, 07:26 PM   eBay Motors   #11 (permalink)
COAL PILOT
Originally Posted by K9Duramax View Post
If it is loosing prime, you have an air leak somewhere- be it the housing, WIF sensor, something...
I understand that part...i was just wondering if there are any spots that rub or...
04 - GMC SLT 2500HD - LB7 - Crew SB - Edge Juice W/Attitude - 4" Turbo Back
COAL PILOT is offline   Reply With Quote
Old 10-15-2009, 04:07 PM   eBay Motors   #12 (permalink)
rwest
Long starts???
I have an 2002 with 144,000 miles. This week I started experencing the same issues. Extremely long crank time prior to starting. Once running is fine. Were you able to find out what was going on with your truck?
rwest is offline   Reply With Quote
Old 10-15-2009, 04:21 PM   eBay Motors   #13 (permalink)
K9Duramax
K9Duramax's Avatar
There is problems with them leaking at the connector where the wire goes in up top, and with the WIF's leaking- there's 2 good spots to check. If you can get someone to help you, pressurize the system (10 pounds max IIRC) through the filler neck and see if you can get it to leak..
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
Old 10-15-2009, 04:39 PM   eBay Motors   #14 (permalink)
lgeorge
With my recent no start experience behind me I recommend using the fuel fitting by the alternator instead of the plug on the filter housing. I used a 1/2" i.d. vinyl hose over the fitting and inserted a straightened out coat hanger down the hose to push on the Schrader valve. With the big hose it's far easier to see if there are any bubbles. You'll know you've got all the air out if the primer is to hard to push without going 1/2 a stroke.
'01 3500 CC LB DRW 4x4 DMax/Allison
Edge/Attitude 150,000 mi.
lgeorge is offline   Reply With Quote
Old 10-15-2009, 04:49 PM   eBay Motors   #15 (permalink)
rwest
I experienced a issue over the summer with the WIF leaking fuel even when closed off out of the pitcock. I have a put a new one on the truck and really hadn't had any problems until the last few weeks. A friend of mine said that the new low sulfur fuel could be part of the problem as it deteriorates the o-rings. How did you resolve your starting problem?
Old 10-15-2009, 06:37 PM   eBay Motors   #16 (permalink)
lgeorge
my problem, as described in the thread, was the heater connection on the top of the filter housing leaking. It would leak out fuel when priming with the plug in and, I assume, allow air to draw in when trying to start the truck. I have effected a repair using epoxy at the base of the fitting.
here's a link to the thread:
'01 duramax no start
here's a link to a pic:
Filter base seeping on top
Old 10-17-2009, 09:33 AM   eBay Motors   #17 (permalink)
rwest
Update. Taking all of the different possible problems, I started with changing the filter, replacing all o-ring and also replacing the screw that allows you to purge the filter of air. I did this yesterday and as of this morning, the truck is now starting with only a few cranks of the engine. Thanks to everyone for all of your input and suggestions.
Old 10-18-2009, 08:31 PM   eBay Motors   #18 (permalink)
COAL PILOT
where and what is the wif...thanks
Old 10-25-2009, 10:49 AM   eBay Motors   #19 (permalink)
Old Hamilton
Wif
WIF stands for water in fuel. It is a sensor at the bottom of your fuel filter. It is threaded in and has a petcock to drain water out the bottom of the filter.
2005 Silverado 2500 HD
Duramax
Regular Cab, Long Bed
Stock
Old Hamilton is offline   Reply With Quote
Old 11-07-2009, 12:27 PM   eBay Motors   #20 (permalink)
09darkdmaxx
09darkdmaxx's Avatar
just installed a new fuel filter and was priming and saw no diesel... so i loosened the bleeder screw a 1/4 turn more and a gasp of air leaked out w diesel!!! is this bad lol??? help
-09 2500hd cc/sb
ppe intake mod with afe pro gaurd 7, turbo resonator block, pvc re-route...edge cs race, dpf delete, no muffler mbrp 4" turbo back,shim kit, egr blocker,diamondeye downpipe,transgo jr., deep pan,ready lift leveling kit, 285/75/16 pro comp xtreme a/t...and a new boss 8'2 power-v xt
in spring: airdog2, tie rod sleeves, cognito tie rod ends, suncoast stage3, afe bladerunner turbo inlet, snow performance stage1 water/meth, bd manifold!!!!
-08 2500hd reg/lb 6.0 (gasser)
flowmaster single cat-back exhast, airaid cold air intake, predator diablo tuner, 285/75/16 coopers, leveling lift
AlligatorPerformance.com/Amsoil syn/Powermaxperformance
09darkdmaxx is offline   Reply With Quote
