| If all else fails, might want to check your injectors. This can be a symptom of failing injectors on the LB7. Matter of fact, we just did one a couple weeks ago at work. Came in as the same thing, longer/extended crank. It was an 03 with only 37k on it.
__________________ 2002 2500HD Crew Cab Short Bed
4" MBRP Turbo Back
PPE Standard, PPE Boost valve, Optix Boost, Pyro, Trans temp
B&W TurnoverBall and tow mirrors self installed
Rhino'd bed, 285 ProComp EXtreme A/Ts & T-bars cranked
Banks RamAir and modded intake horn
Allison Deep Pan with MikeL cooler
(waiting on my injectors to come back  ) |
