Starts and shuts off - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 10-19-2009, 03:34 PM Thread Starter
Hey, i'm new to the forum and i have an 03 duramax. I have a quick question for you guys. If you could help me out it would be greatly appreciated. On cold mornings when i crank my truck, it runs for a few seconds and then it just cuts off. The only way it will start back up is if i prime the fuel filter. I have not plugged the truck in yet, because i just found the block heater plug in. I'm going to try to plug it in tonight and see if that helps. But if anybody has had this problem before and/or has any information on why my truck is doing this i would really appreciate it if you could help me out. Thanks alot.
dtripp is offline
post #2 of 16 (permalink) Old 10-19-2009, 11:10 PM
Tow Master's Avatar
Welcome to the forum!
The fuel filter housing's (where the primer is) are known to leak. Im guessing the rubber seals are brittle and starting to leak letting air in. It starts for a second because there is some fuel left over in the injectors and injection pump.
Jason
Tow Master is offline
post #3 of 16 (permalink) Old 10-20-2009, 03:46 PM
joelb's Avatar
I have been having the same problem. Not just on cold days. are the seals replaceable or do you have to replace the whole housing? Are there any check valves?
joelb is offline
post #4 of 16 (permalink) Old 10-20-2009, 03:50 PM
Quicker Then Brian!
RedBowTies88's Avatar
first things first i would remove the filter and check the o-rings that go with it....cheaper/easier then playing with the housing at first
Beech - 05 LLY CC/SB 4x4
12.31@108.57 On stock turbo and fuel system
Thanks to,
Big Dipper, Efilive, Calvert, Precession Converters, Nick@Duramaxtuner, Eaton, Pureflow, and Falken
RedBowTies88 is offline
post #5 of 16 (permalink) Old 10-20-2009, 03:52 PM
I just recently purchased my 03 from a friend and he was telling me something about this. he said that when its cold out it will start and run for a bit then shut off. He has had it since new and has taken it to the dealer several times because this has happened since he got it new and the dealer never could figure out anything. Then turns out this only happens when there is less than a 1/3 tank of fuel. His advice to me was just keep plenty of fuel in the tank and i wouldn't have a problem. But i also would like to know what the deal is concerning this.
Chris
03 Chevrolet 2500 HD Duramax
CCSB, 6" Fabtech Lift, Suncoast stage IV, EFI Live by Husker Diesel, Air Dog 165, and lots of appearance goodies!
07 Sport trac XLT - Sold
01 Mustang- Sold
94 Seadoo SPX - my water toy
81 Honda Express- my land toy
01 Raptor 660r
Jammin818 is offline
post #6 of 16 (permalink) Old 10-20-2009, 03:54 PM
Quicker Then Brian!
Chris
amount of fuel in the take should have nothing to do with prime...
Thanks to,
post #7 of 16 (permalink) Old 10-20-2009, 06:50 PM
joelb's Avatar
i serviced mine and replaced the fuel filter right befor labor day and it ran fine for a month. now all of a sudden it is loosing prime. i've been told the pickup pump is probably going bad.
joelb
joelb is offline
post #8 of 16 (permalink) Old 10-21-2009, 03:24 PM
I had a similar problem and found the filter housing leaking at the heater connection. Here's the link to the thread:
'01 duramax no start
'01 3500 CC LB DRW 4x4 DMax/Allison
Edge/Attitude 150,000 mi. Injectors @ 154,000
lgeorge is offline
post #9 of 16 (permalink) Old 10-21-2009, 03:57 PM
levi9306's Avatar
^^^^^Try this first ..Same thing happened to me and it was repair shop in OKC over tightened the filter leaving a hair line crack in the housing. Which they denied doing of course. I think it cost me around $700 or so for the new housing.
_________________
2007.5 CHEVY 2500HD LMM CREW CAB 4X4 LTZ
6" PRO COMP LIFT
20" KMC HOSS WHEELS/20" KMC BLACK ROCKSTARS
33" NITTO TRAIL GRAPPLER
QUAD STEALTH 2 @ 70HP
4" MBRP STRAIGHT PIPED
218K
levi9306 is offline
post #10 of 16 (permalink) Old 10-21-2009, 03:58 PM
It all boils down to checking for leaks guys- if you are losing prime, plugging in the truck isn't going to do anything for it. Need to find out where the leak is- look the system over good, and if that doesn't reveal anything, try to pressurize the system through the fill neck and see if it will produce a leak...
'05 CC/SB, AMSOIL 15w-40 (From Synthetic Motorsports), Cold Air Intake with a dry Nanofiber filter from AMSOIL, PPE Tuner level 1, EGR blocked, LBZ MP, lost KITTY, finished off the rest with 4" SS Magnaflow, Amsoil Torque Drive, 5K HID's, General Grabbers 265 :rockin
K9Duramax is offline
