Old 10-27-2009, 10:57 AM   eBay Motors   #1 (permalink)
Firecapt205
Firecapt205's Avatar
Check Engine Light Code 0380
I am getting ready to go out of town and my check engine light came on. Had it scanned and it came back as P0380 Crank Sensor (except diesel) I checked the internet for this code and it comes back as glow plug for the D-max. If it's the glow plug them I am happy since they have a ten year 200,000 warranty. Help please.
03 HD2500 stock 120,000 miles Amsoil in everything
Firecapt205 is offline   Reply With Quote
Old 10-27-2009, 11:48 AM   eBay Motors   #2 (permalink)
DuramaxSMOKE11
DuramaxSMOKE11's Avatar
could be your glow plug control unit
2005 Chevy 2500HD Duramax LLY, Banks ram air intake w/super scoop, Banks 4" exhaust, CAT DELETE and NO MUFFLER, EGR blocker plate & fingerstick, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, PPE standard, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
To come soon
AFE Intercooler, Raptor 150 pump, SunCoast tranny & TC
Big thanks to chad at Alligator performance and Guy at SoCal Diesel
DuramaxSMOKE11 is online now   Reply With Quote
Old 10-29-2009, 11:00 PM   eBay Motors   #3 (permalink)
shdw134
shdw134's Avatar
Mine said same code and was the controller. very easy to change yourself and save a bundle. Didn't fix my problem though. They called me yesterday and i am getting the full injector replacement on there dime.
2003 GMC Sierra 2500 Hd ext. cab short box Stock except for rims and tire. Color matched sprayed in bed liner. Ici nerf bars.
shdw134 is offline   Reply With Quote
Old 11-01-2009, 06:54 PM   eBay Motors   #4 (permalink)
2003sierra2500HD
If you paid for your own glow plug controller replacement you should check this out and get a imbursement from GM. Mine is also a 2003 with LB7 and got check engine light yesterday with DTC P0380.
http://ww2.justanswer.com/uploads/Bl...lug_policy.pdf
2003sierra2500HD is offline   Reply With Quote
Old 11-01-2009, 08:11 PM   eBay Motors   #5 (permalink)
B--S
B--S's Avatar
is it the relay that you can get reimbursed or the actual glow plugs? my relay went a while back and the dealer wanted to charge me for it
2003 Silverado 2500HD CC/LB @ 240k km
4" turbo back, K&N kit, Fitch Fuel Cat... 20mpg mixed driving. 22-23 Highway
B--S is offline   Reply With Quote
Old 11-02-2009, 11:10 AM   eBay Motors   #6 (permalink)
2003sierra2500HD
I assume this special coverage started 2/13/2008. If your repair was done prior then that is the reason why Dealer was going to charge you. But, if you truck was within 5yrs/100K miles dealer should have covered the repair and parts anyway due to being a diesel engine. Check this comment stated on the special coverage "Claims with repair orders prior to February 13, 2008 must be submitted to the Service Contract provider.” Check your last eight VIN on the bulletin if it is listed and you can also call the toll free number to GM to inquire about it.
Old 11-02-2009, 08:49 PM   eBay Motors   #7 (permalink)
TurbDies2500
TurbDies2500's Avatar
I had that code and it was my glow plugs. I got them replaced at the dealer on warrantee.
2003 2500HD Duramax Crew Cab
Edge Power Programmer, 4" Exhaust
Lifted, 33" BFGoodrich All Terrains
TurbDies2500 is offline   Reply With Quote
