Old 11-03-2009, 06:42 PM   eBay Motors   #11 (permalink)
Johnp33
Block heater
Using the block heater is a lot better for your engine to start when it is a little warmer, less wear on the motor, it is a lot cheaper to use electricity to warm up you motor than diesel fuel. I plugged in mine this morning, only for about 15 minutes while I loaded up the truck but better than nothing, left it plugged in while, I scrapped the windows with the truck running. Works for me.
I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Johnp33 is offline   Reply With Quote
Old 11-03-2009, 07:08 PM   eBay Motors   #12 (permalink)
DixonPeer
Lot better for the engine to plug in the block heater on cold nights. I plug mine in when temps overnight get down into the twenties (F) and then in the morning it's an easy start and the cab warms up really quickly. Even with the remote start, the cold block/piston friction will be greater than if you use the block heater 'cause you're starting with parts that have not got the same coating of lubricating oil on them.
DixonPeer is offline   Reply With Quote
