Its getting cold around these parts at least overnight how cold is it when you guys plug your trucks in and how long do you keep them pluged in for I just want to make sure im not over doing it or not doing it enough Thanks guys
__________________ 01 Serria 2500HD LB7 SLT EXT CAB 4X4
Silverline 4in straight pipe turbo back
ppe boost valve
for me...if i am at work...10 above. at home i plug it in before i go to bed if it will be 0 or colder. Although i have a garage, so i dont have to plug in at home. If you have a timer, i would set it for about 3 hours before you would be leaving in the morning
If it is 20F I may plug it in for a while 1/2 hour or so at 0F I will give it an hour. I have the block heater and both batteries have blankets. That reminds me I will put on the full winter front on today. And am going to make up a set of chains to fit her. -20F i will give it a couple of hours. It depends where it is and where it is parked inside she gets less outside in the wind it gets more time.
__________________ I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Looked for my plug for the block heater,can't find it,looked in owners manual it shows where it should be.Do all DMax come with one.It's going to start getting cold in the U.P. of Michigan
