| Why in the world would you want to go to a LB7 other than the miles? Your truck is just broke in. The big thing i would be worried about is the injectors on the LB7 engine. They will eventually go out and that will cost about 4-5,000 to get swapped out.
I would look at the transfercase if it has one...look for the pump rub hole.
You have owned your 04.5 for most of those miles right? you know what it has been through. Is it still running strong with no problems?
AFE Magnum Force Stage 2 Proguard 7 intake Waiting install:Rancho Steering stabilizer....all thanks to NorCal Truck Support your Supporting Vendors |
