I am running a Fass 95 GPH lift pump. With that filtration I didnt know if I should still change the stock fuel filter? Does the lift pump filters filter the fuel to a smaller micron than the stock filter? What do you guys do?
__________________ -Josh
2004 2500 LB7
EFI Live from Husker Diesel
Fass 95 GPH
S&B Intake
MBRP 4 inch
Suncoast Stage IV
Boost Valve
Tie Rod Sleeves
The Fass filters will filter to a lower micron rating than the OEM. The OEM filter will still need to be changed though it may not need to be changed near as often as when you don't have a Fass system.
MadJack Racing & Synthetics MadJack Racing is Your #1 Source For Amsoil And Discount Diesel Parts
Credit Cards Accepted
I have a cat 2 micron filter on my truck and oem 10 or whatever it is, thinking about deleting it.
how often should i change it? Im gonna change all the fluids and filters in a couple thousand miles so just trying to figure all things needed. Anyone reccommend brake fluid flush?
Truck has 67k on it
2004 2500 LB7
Fass 95 GPH
S&B Intake
MBRP 4 inch
Suncoast Stage IV
Boost Valve
Tie Rod Sleeves
Truck has 67k on it
YES the brake fluid flush is SUPER easy. we did Jesse's LMM the other day, takes about 20 minutes... his old fluid was disgusting..
Truck has 67k on it
id say between 10-15k, depending on the quality of fuel you have.
__________________ Brian, 19, 06 LBZ, EFILive, MM Diesel Performance, Alligator Performance, Suncoast, TTS, Cognito, High Tech Turbo, PPE, Magnaflow540rwhp/1000tq. 12.64/107.52
