Old 11-03-2009, 10:27 PM   eBay Motors   #1 (permalink)
add2255
looking @ a lb7
i am looking at a 2004 gmc 2500hd 4x4 with the lb7 it has 174,000 i can buy it for 13000 i have a powerstroke now and am thinking about trying a duramax i calld the dealer and they say the injectors havent been replaced and it seems too be a good truck i know it just had a brand new transfer case installd if anyone can tell me wat to look for on this truck as far as letting me knw if this is a deal on a good truck or it wont last i would like too know thanks
add2255 is offline   Reply With Quote
Old 11-03-2009, 10:37 PM   eBay Motors   #2 (permalink)
ski
ski's Avatar
Ask the dealer to check the balance rates and do a pressure test before you buy it. It's still under the 7/200,000 mile injector warranty so even if you do buy it and the injectors fail your still covered up to 200k. Then you get to battle with GM under the special policy to get them replaced.
My truck is an '02 with 181,000 and the injectors have yet to be replaced. Had the balance rates and fuel pressure checked and everything checked out even though it smokes at bit at idle with the motor hot or cold.
ski is offline   Reply With Quote
Old 11-03-2009, 10:41 PM   eBay Motors   #3 (permalink)
hvy_chevy_one
hvy_chevy_one's Avatar
Id trade a Powerjoke anyday for any dmax.. If its an 04 then the injectors are still under warranty. I think that is a good price on it. I love my LB7, wouldnt trade it for anything
2002 Black GMC 2500HD crew cab LB7.
PPE Standard turned down to 160 (poor tranny)
PPE Boost valve
Straight piped, 4inch tip.
Airaid Intake
Speedliner
T-bars turned up 4 turns
H2 rims with BFG A/T 285's
Optima Red top
Blacked out taillights, third break light, and bottom marker lights
In-Dash DVD
hvy_chevy_one is offline   Reply With Quote
Old 11-04-2009, 09:02 AM   eBay Motors   #4 (permalink)
audiomixer
audiomixer's Avatar
On trading off the powerstroke, I agree if it is the 6 oh or later. I have an '02 with the 7.3 and I certainly would not trade it for a duramax nor the other way around. I like them both. Their mileage is neck and neck. I can get 20 mpg out of both of them under similar conditions and they are both 4WD. My ford is not stock but neither is my duramax. The best part is that my '02 has no emissions equipment.
GMC '04 2500HD SLE CC D/A LB7 SB Summit White, LineX, Nicktane, JK headlight harness, JK fuel pump and harness, Banks exhaust, EFI Live, intake horn mod, Injectors at 112,265 (#8 again at 136K) .
Excursion '02 7.3 PSD Banks Exhaust, DP Tuner and fuel mods.
VW '02 Jetta Wagon TDI.
audiomixer is offline   Reply With Quote
Old 11-04-2009, 03:29 PM   eBay Motors   #5 (permalink)
GMC25HD
GMC25HD's Avatar
The price is right on it your still under warrenty before do anything i would get the injector tested but the lb7 is a great motor all around good luck
01 Serria 2500HD LB7 SLT EXT CAB 4X4
Silverline 4in straight pipe turbo back
ppe boost valve
GMC25HD is offline   Reply With Quote
