Old 11-05-2009, 11:36 PM   eBay Motors   #21 (permalink)
California Duramax
R.V.Tech
California Duramax's Avatar
Throw some additives at it and run,I have a customer in alaska where it is always below 0 and he uses additives so the fuel won't gel,Amsoil makes a good additive Try it
Mike
02 Duramax Black Beauty CrewCab,Long Bed,GT3788 Stage1 Garrett Turbo,Quadzilla Adrenaline Pulse Monitor,50 Gallon Transfer Flow Fuel Tank,5" Exhaust Turbo Back,AFE Air intake,Kenwood nav system
California Duramax is offline   Reply With Quote
Old 11-05-2009, 11:49 PM   eBay Motors   #22 (permalink)
Dgrown
Dgrown's Avatar
at the moment i have none in this tank last time i filled it i though it i had some shit in my injectors so i dumped half a quart of kleenflo fuel system cleaner(gray jug) in along with another half a quart of kleenflo injector and pump lubricator (orange jug). unsure which i should run on a regular basis that tank the truck didnt like any high boost but now that i have the tank filled again with a fresh fuel filter it seems to be running even nicer and smoother then when i bought her
figue i would add this in this seems to be my maintenance schedule i have fallowed with every one of my past vehicles so add anything i may need to change
-15w-40 conventional oil w/Lucas oil stabilizer mixed in
-fuel filter changed every other oil chance
-oil is done around every 5000km
-new air filter every time it goes for an oil change (its black by then)
-allison spin on filter changed every other oil change
-fuel additives still unsure was running fuel system cleaner every tank for a while then stopped and never noticed a difference till lately when it felt like an injector was going
-diff oils changed if there is metal in it or its totally black and thats about it
2003 Chevy Silverado 2500HD 4x4 LB7 Black Ext Cab Short Box...Can't give away all my secrets but possibly all stock
Dgrown is offline   Reply With Quote
Old 11-06-2009, 12:16 AM   eBay Motors   #23 (permalink)
Sierra13
i know what you mean dude...i was up workin right next to the NWT border and it would get -60*C or colder easy, trucks run 24/7...turn them off and they don't start the next morning even if they are plugged in
Sierra13 is offline   Reply With Quote
Old 11-06-2009, 12:49 AM   eBay Motors   #24 (permalink)
shrek
Hello every body. I'm new here and lovin' the site. What about talking to your bother and installing a hotbox in the bed of the truck it connects to your cooling line and and can keep the temp up. They run off diesel from your tank or a stand alone tank usally there in highway trucks or heavy equipment that is left in the field.
shrek is offline   Reply With Quote
Old 11-06-2009, 01:12 AM   eBay Motors   #25 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
yeah i one brand is called webasto...they are pretty spendy, but you can get them to heat your engine and interior.
Old 11-06-2009, 05:46 AM   eBay Motors   #26 (permalink)
AO2005
AO2005's Avatar
is than - 40 in celsius or fahreheit
ALAN
05 lly CC/SB 4" mbrp turbo back no kitty no muffler LBZ mp
res. plugged quadzilla stealth 2 135 tune
AO2005 is offline   Reply With Quote
Old 11-06-2009, 04:20 PM   eBay Motors   #27 (permalink)
deskjet_18
deskjet_18's Avatar
- 40 Celcius
2004.5 LLY Crew Cab, Deep marine blue
Interior: 7" Clarion flip out deck with 2 10" Kicker subs powered by 1000W Kicker amp
Exterior: 285/75/R17 Hankook AT's on rims. Fender flares. Aftermarket hood. Head and taillights. Custom rear full window decal. Custom Blue driving lights.
Engine: AEM Brute force intake. 4" MBRP Turboback. Diablosport Predator. EGR Blocker plate. Intake horn block off.
deskjet_18 is offline   Reply With Quote
Old 11-06-2009, 09:32 PM   eBay Motors   #28 (permalink)
maxxflip
maxxflip's Avatar
-40 C is the same as -40 F
08 LMM
Tuned by ʍʍlʍʍ
maxxflip is offline   Reply With Quote
Old 11-06-2009, 09:34 PM   eBay Motors   #29 (permalink)
maxxflip
maxxflip's Avatar
Definatly Use the high idle.... or get a webastco or similer heater (diesel fired keeps coolant temp at 140 or so) they work great
08 LMM
Tuned by ʍʍlʍʍ
Old 11-06-2009, 09:34 PM   eBay Motors   #30 (permalink)
deskjet_18
deskjet_18's Avatar
haha cool never knew that lol
