Old 11-08-2009, 08:00 PM   eBay Motors  #21 (permalink)
FH Leader's Avatar
I dont know if this could help you. But when I did my tranny I had a c stuck fault code and it was the internal wiring harness. The best thing to do is unplug the harness on the back of the tranny and ohm test between the points.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
My iron is yellow
Id rather be dead then CUMMINS RED!
FH Leader is offline   Reply With Quote
Old 01-22-2010, 08:27 PM   eBay Motors  #22 (permalink)
blownpony99's Avatar
I had the same problem with my ATS install, my harness wasnt completely fully plugged in due to the fact that when I pushed my co pilot plug on to the back of the trans it unseated my through trans plug, and pushed it slightly back into the case. check that, but DON"T pull that pan unless you are ASE certified. all of that is covered in the paperwork that came with your trans. hope that helps
2003 GMC CC/SB 15" Full Throttle Suspension, MURDERED out 20x10 KMC Diesel's Blasted and wrinkle Black Powder coated with 64 1.5" spikes around the lip. on 40" Pro-Comp XTerrains, AEM cold air induction...Stock turbo(with a lil portin)...Edge Juice Box, with Attitude...stacked w/Predator...and the bottle to keep it cool...FASS 150...silverline 4"duals w/5" stainless tips...ATS Allison Extreme w/co-pilot, and 5***** converter...Auburn locker...Cognito steering braces...Heim joint steering w/chromoly sleeves...FTS idler-frame brace...
2WD off-idle launch w/traction issues.....
8.20@89.2 in 1/8th through 3.73's on 40" tires.
blownpony99 is offline   Reply With Quote
