Old 11-06-2009, 11:37 PM   eBay Motors   #1 (permalink)
DieselRacer75
duramax junkie
DieselRacer75's Avatar
Exclamation ats tranny help!!
i had jus purchased a ats stage 3 full tranny for my buddlys lb7 and when we put it in and started the truck its threw 11 codes that were all tranny codes after we cleared them there was only two codes we couldnt erase po842 and po743 please help this is a just outta the crate tranny!!!
thanks
RANDALL - 96 12 valve CUMMINS 4x4, DDP 150's, HTT 64/71/13 turbo, AFE cold air intake ATS exhaust manifold, Dragon Fly pump 4kgs, Full cut DV's, +60 Springs, custom fuel plate, star wheel cranked, plate and AFC housing fwd, suncoast tranny, lock in override switch, triple lock converter, 4 inch exhaust into a black 6'' miter, 52 psi boost.... Oh and NO smoke switch.
JUSTIN - 05 D-MAX 4x4 EFILivetuned by MMLMM, PPE fuel valve, 4in. straight pipe Glow Shift gauges,S&B INTAKE
For all your EFILive wants and needs contact MMLMM
www.mmdieselperformance.com
DieselRacer75 is offline   Reply With Quote
Old 11-07-2009, 12:04 AM   eBay Motors   #2 (permalink)
DieselRacer75
duramax junkie
bump we really need to get this truck going!!!
Old 11-07-2009, 01:02 AM   eBay Motors   #3 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
Give ATS a call or return it for another.
Old 11-07-2009, 08:52 AM   eBay Motors   #4 (permalink)
joelsmith
the king
bump please it my truck lol
03 2500hd dual black six inch miters, intake, ppe hot, pro comp extreme at, airdog 150, glowshift gauges, and billet ats stage three tranny
244k
next ill be gettin efi live, tie rod sleeves, idler and pitman arm braces, and a new center link
and lookin at a fleece turbo
and im gonna put new injectors in when i do that
joelsmith is offline   Reply With Quote
Old 11-07-2009, 10:00 AM   eBay Motors   #5 (permalink)
racinmike77
P0743-- Torque Converter Clutch Circuit Electrical
P0842-- Transmission Pressure Switch, Solenoid C Stuck Closed
2005 Chevy 2500
racinmike77 is offline   Reply With Quote
Old 11-07-2009, 10:24 AM   eBay Motors   #6 (permalink)
DieselRacer75
duramax junkie
how do i get ahold of them on the weekend??
Old 11-07-2009, 10:35 AM   eBay Motors   #7 (permalink)
gossfam
gossfam's Avatar
If you can't get a hold of ATS give Bellflower Trans a call. (562) 867-5240 They are the So Cal. shop reccommended by ATS.
06 2500 LBZ 4X4
gossfam is offline   Reply With Quote
Old 11-07-2009, 11:02 AM   eBay Motors   #8 (permalink)
DieselRacer75
duramax junkie
ok thanx man!!!
Old 11-07-2009, 12:18 PM   eBay Motors   #9 (permalink)
DieselRacer75
duramax junkie
they wnt answer i need help fast please can anyone help
Old 11-07-2009, 01:42 PM   eBay Motors   #10 (permalink)
racinmike77
yea soleniod C is stuck closed, why dont u take the valvebody apart and look into that.
2005 Chevy 2500
