Oil pressure issue - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 01-21-2008, 06:07 AM Thread Starter
Oil pressure issue
I had an issue with my oil pressure this morning, Here are the specifics.
2004 Silverado, 2500HD (78,000 Miles), 4X4, Crew Cab, Duramax (LB7), Allison.
This is long winded so bear with me.
It was chilly this morning around 19F. I started the truck and the oil pressure was normal for a cold weather start (80). But a couple of miles down the road I noticed it had went into the red, and down to Zero as I let off the gas, but would briefly reach 20 if I accelerated.
I never once got a check engine light or low pressure chime . I pulled over to make sure I had oil (it was full), and didn't blow a filter (it didn't). I turned around went home and shut it down. When I started it back up everything was normal. I did not get faulty readings from any other gauges.
Any ideas guys? I suspect a gauge. I'm taking it to the dealer today.
mjjjweber is offline
post #2 of 15 (permalink) Old 01-21-2008, 09:46 AM
Yep!
deeretracks's Avatar
Im hate to ask but did you let it worm up first? If not it could be that the oil was to coldand thick and it just could not flow proper..Just my thought.
Craig
deeretracks is offline
post #3 of 15 (permalink) Old 01-22-2008, 06:20 PM Thread Starter
Ya, it was wormed up; actually it was a few miles down the road before it happened.
I took it to the dealer and they said the gauge cluster was bad; there is actually a service bulletin out on this very problem.
Thanks for the reply.
post #4 of 15 (permalink) Old 01-22-2008, 11:38 PM
Maverick684's Avatar
Yeah mine has been acting a little funky lately. When I start it, it goes to 70 until I start driving it even after being warmed up. We have had some cold mornings for our area like in the teens every morning. BTW my speedo gave my the finger about a month ago. Time for a new cluster.
John
05' Dmax LLY CC SB, 6in.Fabtech, 20x12 Fuel Krank's, 35in Trail Grapplers and some other stuff
2012 Jeep Grand Cherokee SRT8
2003 Cummins SC LB
Maverick684 is offline
post #5 of 15 (permalink) Old 01-23-2008, 12:00 PM
Supper's Avatar
Send a message via AIM to Supper
Any more info on this service bulletin? I also have some oil pressure gauge issues even after warming the truck up. Especially when we get down in the -20F range.
2003 GM 2500HD Auto CrewCab Short Bed 130,000 miles. No longer bone stock. 5" turbo-back straight pipe & PPE Standard Xcelerator, transmission and suspension on its way once I can afford them
Supper is offline
post #6 of 15 (permalink) Old 01-23-2008, 01:26 PM
Diesel-N-Dust's Avatar
Yep.It is the guage cluster. Mine did the same thing.
Diesel-N-Dust is offline
post #7 of 15 (permalink) Old 03-27-2008, 11:02 AM
BowtieBrian's Avatar
Hey all, I jsut started having the same issue with my oil guage (the needle now pegs out when I go down the road), but I am well over the 70,000 miles GM states in the recall ... anyone have any ideas on the cost to have it fixed?
BowtieBrian is offline
post #8 of 15 (permalink) Old 03-28-2008, 07:06 AM
wgr73's Avatar
Mines doing this too. After I had a car alarm put in yesterday it started doing this...before this it was fine! I think I read in another thread that if you turn off the truck, put it in park and pump the brakes twice it will go away?! Maybe someone can tell me if im right....I sure hope so, I need to get rid of this problem.
wgr73 is offline
post #9 of 15 (permalink) Old 03-28-2008, 09:14 AM
zvacman's Avatar
Last July 5th mine dumped an oil pressure sending unit, but I got the low oil pressure chime.
Z
zvacman is offline
post #10 of 15 (permalink) Old 04-05-2008, 02:39 PM
Question
Z
ya me too! my oil pressure gauge flickers all over the place when it gets low the DIC says low oil pressure.. on a long trip it gets pretty annoying..i changed the oil pressure sensor and it didn't fix it $104 how do i fix it????...cluster was changed a year ago.. let me know thanks
2003 Dmax GMC ext-cab shortbox carbon metallic..PPE Stage 3..Boost valve..Kennedy air intake..nitto 285's..Alpine deck..amp..JL audio subs..A-pillar boost gauge:rockin
03 Dmaxer is offline
