Old 11-13-2009, 02:39 PM   eBay Motors  #1 (permalink)
Stiemy's Avatar
Operating Temps?
Hey guys I am new to Diesels and was just wandering what the normal operating temps were? I am talking engine coolant of course. Mine runs around the 180 - 185 degree area is that normal? Sorry for the noobie questions but I have only had gassers in the past that run around the 200* mark.
04' ECSB 4x4, Line Xed
Nerf bars, Edge Juice
that is all for now!
www.alligatorperformance.com
Stiemy is offline   Reply With Quote
Old 11-13-2009, 02:49 PM   eBay Motors  #2 (permalink)
JuniorDiesel's Avatar
Yep, that's normal. Mine was around 185-189 yesterday when I drove over 300 miles.
2007.5 Silverado 2500HD LMM
MBRP 4" DPF back exhaust, H.I.Ds, Billstien 5100's, 18" XD Monsters WAITING FOR SOME TIRES!!
AMSOIL
www.syntheticmotorsports.org
JuniorDiesel is offline   Reply With Quote
Old 11-13-2009, 02:54 PM   eBay Motors  #3 (permalink)
another red name!!!
ob_1jr's Avatar
Yep that is what mine runs in the winter...in the summer i do see 210 until the thermostat opens up.
Racor 2 Micron pre-OEM with heater & water sep.
Old 11-13-2009, 04:34 PM   eBay Motors  #4 (permalink)
Stiemy's Avatar
Thanks for the input fellas I appreciate it.
Old 11-13-2009, 04:38 PM   eBay Motors  #5 (permalink)
Night Owl's Avatar
what is everyone amp gage showing ? not to trying to change the subject! mine shows around 16+ is that normal?
Tim
2001 2500hd lb7 a/t ec/sb leather,straight pipe,westin steps,intake horn mod,billet grille emblem,mldgs removed,partially debadged,Quadzilla S2,K&N filter,Chrome H2 wheels wrapped in 285 70 Kuhmo"s,t-bars cranked,tow mirrors,4inch MBRP exhaust on the way.
perfomancetruckproducts.com
"I've drank enough whiskey to float a battle ship around" Ronnie VanZant
Night Owl is offline   Reply With Quote
Old 11-13-2009, 04:46 PM   eBay Motors  #6 (permalink)
EFI'd and lovin it
Johnasara's Avatar
16 is too high. It should be around 14 to 14.5
4" DIAMOND EYE EXHAUST,
EFI LIVE,DSP5,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....
WORK RIG
DPF GONE!!!EFI LIVE,DSP5, K&N FILTER, MAF CLEANER IN BED
This is not only your forum you have to share it with over 30,000 others
Old 11-13-2009, 05:40 PM   eBay Motors  #7 (permalink)
Night Owl's Avatar
so a new alternator?
Tim
Old 11-13-2009, 05:46 PM   eBay Motors  #8 (permalink)
Ridin'GMC's Avatar
Pretty much. The voltage regulator is failing to do its job. It's built in the alternator so you pretty much can't rebuild it like back in the old days you can replace a voltage regulator or a diode.
06 LLY CCSB
Just another white truck on the site.
Tuned by Killerbee's Original LBZ tune.
KB's tuning - 480 rwhp & 830 lb-ft of torque as of 11-7-09 on stock engine and stock tranny **still running with a cat on**
killerbeeperformance.com
Ridin'GMC is offline   Reply With Quote
Old 11-14-2009, 03:22 PM   eBay Motors  #9 (permalink)
Night Owl's Avatar
checked the amp gage today it is 2-3 marks past 14.
Tim
Old 11-14-2009, 05:01 PM   eBay Motors  #10 (permalink)
GMC25HD's Avatar
I run at 185 all day so you are right were you need to be
01 Serria 2500HD LB7 SLT EXT CAB 4X4
Silverline 4in turbo back straight pipe
ppe boost valve
Stealth 2 50hp tune
GMC25HD is offline   Reply With Quote
