| mine does it on occasion, its a 04 lb7 all stock. when i start it the brake/abs light comes on, if i shut it off and restart it goes off. when its on, ive scanned it and says "no communication". im a technician and have found issues with the wire that supplies power to the abs module, corrodes and pulls voltage down so it cannot send the message through the can bus system. i havent had time to find exactly where the problem lies but when i do i will do a full write up on it. that the problem with being a tech, i fix everyone elses stuff but when it comes to mine i put it off. like i said mine olny does it once in a while and i ignore it cuse the next time i start it it wont be on. also it does it more frequent in colder temps below 35 degrees or so, did it only once or twice over the summer.
__________________ 2004 chevy 2500 hd lb7 ec/sb stock for now..... |
