Glow Plug wiring diagram - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 12-10-2009, 03:35 PM Thread Starter
Does anyone have a wiring diagram for the glow plugs? I think I have a short after the gp controller, but I'm having some serious trouble tracing the wiring.
Also, on a related note, can someone tell me where the glow plugs are located physically?
I should add that this truck does not have CA emissions.
Thanks!
Jason S.
'02 GMC 2500HD 4X4 LB7 6 speed
Nictane
Fulid Damper
South Bend Single Mass Flywheel
Transfer case pump fix
Last edited by unbalancedengineering; 12-10-2009 at 03:38 PM. Reason: No CA emissions
unbalancedengineering is offline
post #2 of 20 (permalink) Old 12-11-2009, 08:41 AM Thread Starter
Does anyone at least know where the glow plugs are located? Thanks,
Jason S.
Nictane
Fulid Damper
post #3 of 20 (permalink) Old 12-11-2009, 08:43 AM
delong_1's Avatar
if you pull the inner fender liner, you will see them. they are in the side of the head in the same general area as spark plugs on a gas motor.
built motor, big turbos, built trans, etc all by me, parts from Elite Diesel
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #4 of 20 (permalink) Old 12-11-2009, 08:50 AM Thread Starter
Thanks Nate!
Nictane
Fulid Damper
post #5 of 20 (permalink) Old 12-11-2009, 08:57 AM
delong_1's Avatar
on the drivers side there should be a wire on the front and rear glowplug and a rail from the front across each of them to the rear.
on the pass side i cant be sure if there is two wires or not. but there should be a wire and then the rail across the plugs.
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #6 of 20 (permalink) Old 12-11-2009, 08:59 AM Thread Starter
Do you know if the rail sees ~12V when the glow plugs are operating? Thanks a ton!
Jason S.
Nictane
Fulid Damper
post #7 of 20 (permalink) Old 12-11-2009, 09:09 AM
delong_1's Avatar
im not sure about voltage but they should see some power.
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #8 of 20 (permalink) Old 12-11-2009, 09:23 AM
Administrator
ob_1jr's Avatar
check this out..see if this helps.
hmmm doesnt seem to be big enough..pm me your email and i will email it to you.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #9 of 20 (permalink) Old 12-11-2009, 09:41 AM Thread Starter
I got your email. Thanks guys!
Jason S.
Nictane
Fulid Damper
post #10 of 20 (permalink) Old 12-11-2009, 10:45 AM Thread Starter
That is exactly what I needed. Thanks Scott!
Jason S.
Nictane
Fulid Damper
