Old 02-09-2008, 06:48 PM   eBay Motors   #1 (permalink)
milburnHD
howling sound
Hey guys, my truck is maing a howling sound only at very low speeds once it warms up a bit and comes and goes. I just had to replace the transfer case (just bought the truck) and changed all fluids in the truck as they weren't in great condition. I know they're all full because I can;'t see any leaks. Almost sounds like it's coming from the tranny but can't be sure, Does anyone else's truck make this noise also?
Thanks
DRIVER: 2003 GMC 2500HD 4X4 SLE EC/SB LB7
LT285/75/R16 MICKEY THOMPSON BAJA ATZ RADIALS
CUSTOM TUNE BY BR POWERSOURCE, TORSION BARS CRANKED SLIGHTLY COMING SOON 4" TURBO BACK W/ 5" POLISHED TIP,RAM AIR INTAKE
DUMPER: 2003 GMC C4500 REG CAB 2WD LB7 ZF6
12' DUMP BOX NEW INJECTORS STOCK FOR NOW
TOWS 8000LBS AND HAULS 6000LBS SIMULTAENEOUSLY DAILY
milburnHD is offline   Reply With Quote
Old 02-09-2008, 07:01 PM   eBay Motors   #2 (permalink)
wildturkey_hunter
wildturkey_hunter's Avatar
Could it be your fan clutch mine really howls at first then it goes away unless its pretty warm then it comes and goes with engine temp.
2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator
wildturkey_hunter is offline   Reply With Quote
Old 02-09-2008, 07:50 PM   eBay Motors   #3 (permalink)
deeretracks
The Sheriff
deeretracks's Avatar
Check your front wheel bearings. Thy are a common prob on these trucks.
Craig
2001 Chevy, 4 door, short bed,D-Max, 2 wd.
Special Thanks goes to the person in the WAL-MART parking lot for installing it for me,
Old 02-09-2008, 11:49 PM   eBay Motors   #4 (permalink)
ob_1jr
Super Moderator
ob_1jr's Avatar
the tranny does make some noise, but I would describe it as a whine and not a howl. Mine makes this sound almost all the time and it doesn't really change. As far as a howl, the wheel bearings are a constant problem....but it normally gets worse with speed. Mine howls when I am in 4wd on the highway.
4" turbo back MBRP exhaust
Kennedy Diesel
Merchant Automotive
My Photos
Old 02-10-2008, 11:43 AM   eBay Motors   #5 (permalink)
greatwhitecracker
greatwhitecracker's Avatar
Thanks
Before I had my injectors replaced my truck was making a howling sort of noise after starting in the morning, but I haven't heard it since the fix. Is your truck smoking?
2003 GMC 2500HD 2WD E/C S/B W/LB7
New Injectors-158,174
stock exhaust straight piped
Predator (only used to check balance rates)PPE Boost Valve
VENDORS...I'M LOOKING FOR A 5''T/B EXHAUST ALUM OR SS PLEASE PM W/PRICE 10/24/08
greatwhitecracker is offline   Reply With Quote
Old 02-11-2008, 05:52 PM   eBay Motors   #6 (permalink)
milburnHD
Thanks for all the replies fellas, apparently the wheel bearings were both done when the truck was being safetied, I'm thinking it must be this tranny whine as it goes away once the truck gets above 7-10mph, guess I'll just keep respecting her and see if it progresses or not. Thanks again.
