Power Steering Flush and Brake Fluid Flush - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 01-09-2010, 08:35 PM Thread Starter
hi All
The truck has about 250kms on it and I was reading in the DIY section about the brake fluid and power steering flushes.
I have never really thought about doing them before.
I would reccomend everybody do these flushes!!
They are simple and the results are noticeable.
The steering is silky smooth adn the brakes have a lot more feel to them. both are very easy to do as well!!
A big thanks to the two that posted those DIY's!
2002 Chevrolet 2500HD LT CC Short Box with 230,000 KMs. Pacbrake, Superchips tuner, modded stock airbox
Redram99 is offline
post #2 of 12 (permalink) Old 01-11-2010, 06:29 PM
this is a super great site for seasoned gear heads and newbies when it comes to these trucks!
carter4612 is offline
post #3 of 12 (permalink) Old 01-11-2010, 06:31 PM
I agree, it is small change to flush them both, but it makes a world of difference. They are often the most neglected fluids other than grease fittings in the vehicle.
bigdaddydiesel is offline
post #4 of 12 (permalink) Old 01-12-2010, 07:53 AM Thread Starter
No kidding... this is the first vehicle I have done this to and I have put a lot of time behind the wheel on other vehicles.
I just never thought to do it before!!!
This site is great!
Redram99 is offline
post #5 of 12 (permalink) Old 01-12-2010, 08:47 AM
Administrator
jc1843's Avatar
It is a good idea to flush the system-, I also added a cooler when I did mine.
This is almost a kit (cooler, bolts, hose and clamps) Has almost everything you need to add the cooler. I used Summit 13222, 12 inch cooler. I mounted it to the tabs on the bumper- I had to buy 2 large washers and a hose connection to connect to the original return hose. I think I paid $22 for the cooler. It hangs behind the bumper, but is still in the air stream. Good cheap mod.
jc1843 is offline
post #6 of 12 (permalink) Old 01-23-2010, 08:48 AM
Does anybody have instructions or know where i can find the proper way to flush those systems? My steering is Terrible at low speed, and I have 37'' tires which is not helping the cause. I dont want to replace the pump if that is not whats wrong. Any suggestions?
monster92884 is offline
post #7 of 12 (permalink) Old 01-23-2010, 08:50 AM
mrmanners's Avatar
Check out the DIY section on here. If I can help with fluids just let me know.
Take care,
mrmanners is offline
post #8 of 12 (permalink) Old 01-23-2010, 09:37 AM
gr8shot's Avatar
Here's the hydroboost flush:
http://www.duramaxforum.com/forum/di...ost-flush.html
Brake fluid flush:
http://www.duramaxforum.com/forum/di...tem-flush.html
Enjoy your new silky smooth steering, and great feeling brakes
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #9 of 12 (permalink) Old 01-23-2010, 09:41 AM
Its just a worktruck
DMAXchris's Avatar
I REALLY need to do this.
06 LBZ EC/LB 4x4
Built Motor/Trans • Bullseye s475/87/.9 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance • 11.76 @ 115
DMAXchris is offline
post #10 of 12 (permalink) Old 01-23-2010, 09:48 AM
gr8shot's Avatar
It's easy as pie chris. When Jess and I did mine, we did two other trucks along with it, and it only took maybe an hour and a half tops to do the HB and Brake fluid flushes on all 3 trucks. It's a lot easier with 2 guys tho, I'll admit.
Jesse
2004 LB7
Tastefully modded
Lots of miles
gr8shot is offline
