Does my truck have a Block heater - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 01-31-2010, 04:28 PM Thread Starter
the-sandman's Avatar
Hey guys,
my truck is a 2004 2500hd crewcab 4x4
i dont drive it everyday and it is sitting outside in 10 deg weather.... if it sits for more than 2 or 3 days it wont start
I was told that all later model desiels have block heaters from the factory...
i have looked and dont seem to find a cord anywhere...
is that true, would my truck have a block heater? if so where is it?
2004 chevy 2500hd duramax crewcab 4x4
Quadzilla Stealth 2 with only 90hp tune, Quadzilla Scout monitor, magnaflow 5" Stainless Exhaust, 3" lift, XD 20x10 wheels, MT ATZ 305/65R20, bullbar, custom grill, nerf bars, toolbox, LED Taillights
the-sandman is offline
post #2 of 12 (permalink) Old 01-31-2010, 04:32 PM
Less than desired
GOB_lly's Avatar
My 2004 has one and was already out when i bought it. But my dads 08 has one and the cord is coiled up ziptied iirc in the passenger inner fender
Dustin
2008 LMM CCSB LTZ... She got that "good good," full deletes, stack, 20s, and some other stuff...
2004.5 LLY sold
GOB_lly is offline
post #3 of 12 (permalink) Old 01-31-2010, 04:49 PM
GMC25HD's Avatar
you have one it is on the pass. side next to the battery it is zip tied next to some other wires it is hard to see sometimes its there you just have to dig good luck
01 Serria 2500HD LB7 SLT EXT CAB 4X4
Silverline 4in turbo back straight pipe
ppe boost valve
Stealth 2 50hp tune
GMC25HD is offline
post #4 of 12 (permalink) Old 01-31-2010, 04:52 PM
Ridin'GMC's Avatar
It should be right next to the fuel filter near the frame. Mine came with it, although I don't need it in the warm weather here.
06 LLY CCSB
Just another white truck on the site
Stock engine and trans.
Ridin'GMC is offline
post #5 of 12 (permalink) Old 01-31-2010, 04:53 PM
Less than desired
GOB_lly's Avatar
I wish that was the case
Dustin
2004.5 LLY sold
GOB_lly is offline
post #6 of 12 (permalink) Old 01-31-2010, 04:57 PM
Ridin'GMC's Avatar
Yep. It's 65 degrees here and it was warm enough for me to wash under the hood and mow the lawn
06 LLY CCSB
post #7 of 12 (permalink) Old 01-31-2010, 05:01 PM
mxhead6.6's Avatar
-25C here at night...and i dont have a block heater...nor can i find it...stupid thing!
2006 silverado 2500hd loaded,blue LED conversion, cobalts, CTS,6'' skyjacker, softride springs
mbrp down pipe, 4'' straight pipe, 7''mbrp stack,
EFI live DSP5
Ignited 8000k low beams, highbeams, fogs.Banks ram air,bushwaker fender flairs,35'' Nitto Mud Grapplers
RBP 18'' 94r's, RBP RX-2 running boards, RBP RX HD Grille,BD turbo gaurd,Airdog2 165,Longhorn Fab Shop trac bars,alpine 7'' double din, 2 Type S's under the rear seat,trainhorn
Tranny and spinny thing to come!
mxhead6.6 is offline
post #8 of 12 (permalink) Old 01-31-2010, 05:01 PM
Less than desired
GOB_lly's Avatar
Never got above freezing today. Really need to wash the truck.
Dustin
2004.5 LLY sold
GOB_lly is offline
post #9 of 12 (permalink) Old 01-31-2010, 05:22 PM
THFD335's Avatar
Send a message via Skype™ to THFD335
like the other guys said it is along the pass fender. its black with a black cap covering the prongs of the cord. hope this helps.
also check your glow plugs and the glow plug conductor. the conductor is a a bar that runs to each glow plug. apperently our trucks have a problem with the conductor bar rusting. i know because i am in the process of replacing mine.
id say you might have some sort of problem like that. it has been in the single digits here and i let mine sit for over a week not pluged in and it started but with a BUNCH of white smoke. that is how i knew i had a problem with my plugs.
-Gregg
06 Chevy 3500 LBZ Crew Cab 4x4 long bed
EBC Yellow stuff pads, Bosch rotors, Russell S.S. lines
5 inch Diamond Eyes turbo back with QT muffler
Down pipe wraped
PPE manifolds and Uppipes
AirDog II 165
B&W turnover ball
EFI Live tuned by Nick
THFD335 is offline
post #10 of 12 (permalink) Old 01-31-2010, 06:52 PM Thread Starter
my glow plugs are working fine the truck just doesnt have enough juice after turning them on to crank the truck more than 15 seconds.....And again that is sitting outside in 10 deg weather for 2 to 3 days
i am assuming i have a couple borderline batteries... i just dont want to buy them now
