cooling system problem - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 02-11-2010, 09:46 PM Thread Starter
lb7duramax's Avatar
Exclamation cooling system problem
Just bought a used 02 chevy duramax with 175,000 miles. Drove for about two weeks with no problems untill i put an egde juice, exhaust, intake, fass fuel and manifold on. couple days later my low coolant light came on and filled it up about two weeks later same thing. my temp never gets above 160 unless really working it then about 190 if im lucky. yesterday morning my temp went from 150 to about 60. this happened one other time about two weeks ago. this last time got curious and like an idiot opened cap and got coolant bath. left my truck at work not wanting to drive it till i get some better input on what the problem(s) could be and what to do next. I had planned on flushing coolant and changing t-stats. is it possible there is more to my problem yet????? any and all input would be greatly appreciated... thanks
lb7duramax is offline
post #2 of 5 (permalink) Old 02-11-2010, 10:05 PM
1953drtelco's Avatar
Let your truck sit overnight after running it....If the top radiator hose is hard, there is a possibility you have a head gasket leak...Hopefully it's a thermostat...
2005 HD2500 Silverado 2WD EC LB (FE9 - Federal Emissions) 115K miles Goodyear Wranglers 265/70R/17,
LBZ mouthpiece upgrade, BD Exhaust, MBRP DP, Banks Ram-Air with SuperScoop ,4" SS Corsa Exhaust System w/gutted kitty, Amsoil Dual Oil Bypass Filtration, Aux Radiator (Engineer 837) installed, Firestone Air Bags, Allison extra capacity Tranny pan, MagHytec Rear Diff Cover, Synthetic Fluids ...Mike L tranny cooler) 2008 Towing Mirrors with Leveling MOD, PCV reroute, Fumoto Valve, Mad Jacks fuel fiter access door. Running 2% BioDiesel with Optilube XPD,TTS dual lift pumps with Nictane Aux Fuel Filtration. EFI (Tuned ECM from Duramaxtuner) Edge Insight CTS to control the tunes
And the best part of all, no payments and title in hand
1953drtelco is offline
post #3 of 5 (permalink) Old 02-11-2010, 10:07 PM Thread Starter
lb7duramax's Avatar
the hose is hard after sitting over night, so that leads to a head gasket for sure??
2002 chevy 2500hd crewcab long box
six inch lift, w/ 35's, edge juice cs w/ EFI
4" MBRP turbo back, S&B intake, BD manifold
Fass Fuel Pump, ARP studs grade C gaskets
ranch hand bumpers and headache rack built by me and line x
recon smoked cab lights, tow mirrors
Cognito pitman, idler supports, HD tie rods, and spicer Pitman/idler arms
zf6 swap
post #4 of 5 (permalink) Old 02-12-2010, 04:43 PM
Siewell Dmax's Avatar
on the LB7 that is not a 100% indicator. I have proof in my own truck that I just finished and it was 2 injector cups that were leaking.
(FOR SALE) 2004 Silverado 2500 HD, LB7, Resonator capped, shiny mod's - billet door handles and buckets, Centerline Blackfoot forged wheels, and a drop in K&N filter. New Headgaskets, Injectors, Cups, Turbo and Nicktane Cat Filter mod. ****(AND IT IS FOR SALE)****
Siewell Dmax is offline
post #5 of 5 (permalink) Old 02-12-2010, 04:59 PM
Ask one to be one
usafracer's Avatar
I would start with a new cap for the coolant resivor. There is a good chance the vent in yours is not working.
Marty
2010 GMC Sierra CC SB 4X4 Cognito 6" lift and 315/70/17 ATP Tuned!!
2008 GMC Sierra Crew Cab 4X4 (wifes) Zone lift set close to 4" 305/70/17's Hankook Dyna Pro RF-10 ATM
usafracer is offline
