Ball Joint Tool - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 02-20-2010, 06:46 AM Thread Starter
Ball Joint Tool
Does anyone know where I can get a ball joint tool to press them in and out that is fairly inexpensive.
02 CC LB LB7, PPE Hot, PPE Boost Valve, PPE Pitman/Idler Arm Support Kit, Fabtech HD Tie Rods, BD Exhaust Manifold, Ready Lift Leveling Kit, 285-70-17 Toyo's AT II LR E on H2 Rims, Airaid Air Intake, Magnaflow 4" Exhaust, PIAA 580 Fog and Driving Lights, Modded Intake Horn, Kool Vue Mirrors, DDM HIDS 6K Low and 8K Highs, Firestone Airbags, Tekonsha P3, Nicktane with Cat
www.huskerdiesel.com 402-502-6961
www.madjacksynthetics.com
02 FL Duramax is offline
post #2 of 5 (permalink) Old 02-20-2010, 06:59 AM
Night Owl's Avatar
Any autoparts store should have them,or harbor freight tools
Tim
2001 2500hd lb7 a/t ec/sb leather,intake horn mod,billet grille emblem,mldgs removed,partially debadged,Quadzilla S2,K&N filter,Chrome H2 wheels 285 70 17,t-bars cranked,4inch MBRP axle dump exhaust with 5" tip,Aero turbine muffler,leveled tow mirrors and a huge wish list.
Night Owl is offline
post #3 of 5 (permalink) Old 02-20-2010, 07:13 AM
Its just a worktruck
DMAXchris's Avatar
You should be able to rent one from a local autoparts store. Make sure its a good one, not some pos chinese junk. I've bent 3 made in china ones.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #4 of 5 (permalink) Old 02-20-2010, 08:12 AM
Renting one is usually best since you don't use it much
2009 2500HD LMM
All stock and plan to keep it that way!
I must be old.....
rgthoma is offline
post #5 of 5 (permalink) Old 02-20-2010, 09:12 AM
If you've got an Oreilly auto parts near you. the brand they carry as a rental works great, just make sure you rent the ball joint seperator as well if you don't have one.
BlackHD628 is offline
