oil leaking from front of engine - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 03-21-2010, 05:52 PM Thread Starter
I have 02 with 67k mi and ha ve a huge oil leak. It started with the smell of fuel and a rough idle. I thought these may be from a recent fuel filter change and added fuel injector cleaner. Today notice residue on tailgate then a huge oil slick under front it looks like it is coming from front of block right behind bottom pulley of serpentine belt.It seems more oil when motor is shut down then when running.After 8 qts of oil and a 40 mi trip to get home leak has seemed to slow down but still has a constant flow. I'am new to the forum and I'am by no means a mechanic so take it easy on me and please HELP! One last thing the truck has never had injectors replaced never noticed loss of power or any other problems.
002dually is offline
post #2 of 15 (permalink) Old 03-21-2010, 06:01 PM
q10559's Avatar
It sounds like you're leaking fuel into the crankcase. Check your oil level and see if you have fuel in it. Iou're losing injectors.
Matt
*SOLD*02 Chevy 2500 LB7 CC LB ZF-6 speed 97k miles 4X4 toolbox,
UltraLite II Boost/Pyro
B&W Gooseneck hitch
285/75/16 Firestone Destination A/T
Straight piped
q10559 is offline
post #3 of 15 (permalink) Old 03-21-2010, 06:08 PM Thread Starter
Thanks for responding so fast. Checked oil on ground and on dipstick no smell of fuel and color of oil looks ok. If it is fuel in crankcase would it be pouring out front of engine like that and if injectors would'nt there be some kinda of other problems? like loss of power fuel mileage loss smoke fuel in air cleaner Thanks again will be waiting for your reply
post #4 of 15 (permalink) Old 03-21-2010, 06:52 PM
John Deere Parts guy
DMAXfirefighter's Avatar
I didn't lose any power or performance when I was getting fuel in my oil. Never posed a problem at all, just lost fuel mileage and smoked some. I just happened to check my oil about 500 miles before I was due for an oil change, and saw that the level was too high. I would think you've got something else goin on here
Play truck - 2002 LB7 2500HD Crew Cab Short Bed
Daily Driver/Tow Rig - 2007 LBZ 2500HD Standard Cab Long Bed
SOLD2006 LBZ 2500HD Crew Cab Short Bed
Traded:2002 2500HD Crew Cab Long Bed
SOLD:2001 2500HD Ext. Cab Long Bed
DMAXfirefighter is offline
post #5 of 15 (permalink) Old 03-21-2010, 07:30 PM Thread Starter
Thanks Matt Like I said fuel mileage is good no extra on dipstick no smell of fuel in oil. Have been reading other posts, could it possiably be PCV valve is clogged? but it does not look to me like oil is coming from blowbytube.
post #6 of 15 (permalink) Old 03-21-2010, 07:47 PM
It could be, but without knowing what your truck is, its hard to say. Fill out your signature so we know more about your truck, and can help diagnose your problem better
post #7 of 15 (permalink) Old 03-21-2010, 07:53 PM
Kroggs's Avatar
Not possible if you added 8 qts of oil.... Dab dipstick on paper towel and tellus what hapens. Although you may have just blew a seal out....
2005 LLY Gmc 3500 CC/LB not bone stock I have a brake controller!!!
Thanks to Tyler @ www.meyerperformance.com
Thanks to Chad @ http://www.alligatorperformance.com/
http://www.facebook.com/group.php?gi...?id=1210592953
Originally Posted by MNDiesel View Post
I hate to derail, but how do you get a quote in your sig?
Like this^^^^^^^
Kroggs is offline
post #8 of 15 (permalink) Old 03-21-2010, 08:08 PM Thread Starter
Went to do signature not sure I did it right not real good with this computer crap. Bot its 2002 chev 3500 dually no mods. Also truck is at buddies backyard garage taking day off tommorow to get closer look.When I parked it went back out 45 min later oil on dipstick where it supose to be no extra.
Roger 2002 chev 3500 crew cab dually no mods just k&n air
post #9 of 15 (permalink) Old 03-21-2010, 08:13 PM
Durallymax's Avatar
It really sounds like injectors. But if it is not the injectors, then hmmmm.
Oil normally comes out the front of the engine on the passenger side, that is where the PCV vents on LB7s. But there should only be a little. The only time there is a lot is when the injectors fill the crankcase full of fuel.
You could have a bad crank seal too, but there isnt much for things that could cause oil leaks up front.
Durallymax is offline
post #10 of 15 (permalink) Old 03-21-2010, 08:24 PM Thread Starter
Well I guess I'am going to have to accept its injectors did'nt want to believe it and still don't want to believe it. I guess the stealership will be happy way out of the seven year warranty but way below the mileage. Third maybe fourth generation GM man but I just about had it with GM. Thanks everyone you've been a big help.
