P0181 - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 04-07-2008, 04:27 PM Thread Starter
delong_1's Avatar
P0181
ive got a P0181, i noticed because i nad no power today, i was wondering what i need to do to fix this properly instead of just clearing the code, any suggestions would really help thanks nate
built motor, big turbos, built trans, etc all by me, parts from Elite Diesel
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #2 of 15 (permalink) Old 04-07-2008, 04:30 PM
BryanVilaubi's Avatar
Bad Fuel Temperature sensor
2003 GMC Sierra LB7
New motor in the works as we speak with lots of goodies!!!
BryanVilaubi is offline
post #3 of 15 (permalink) Old 04-07-2008, 04:34 PM Thread Starter
delong_1's Avatar
where is that sensor located
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #4 of 15 (permalink) Old 04-07-2008, 04:47 PM
Don't know!!!! I've never had to replace mine......someone correct me if i'm wrong but possibly in the fuel filter housing????
2003 GMC Sierra LB7
post #5 of 15 (permalink) Old 11-13-2009, 06:35 AM
03-GMC's Avatar
So i got this code yesterday didnt throw a check engine light just ran like it was stock on my big tune. Did you ever figure out where the sensor is and if that was the fix???
Thanks,
Derek
2003 GMC LB7 CC/SB
EFI by IdahoRob, Extreme Prejudice Built Trans, SDP Twins, UL-II Gauges, 5" Straight Pipe, PPE Boost Valve, FASS Fuel Pump (150GPH), Modded Intake Horn
12.78 @ 105, 657HP
-Derek
03-GMC is offline
post #6 of 15 (permalink) Old 11-13-2009, 07:02 AM
DuraMac's Avatar
Send a message via AIM to DuraMac Send a message via Yahoo to DuraMac Send a message via Skype™ to DuraMac
I used to get this in the winter using the block heater, apparently the sensor activates the DTC because the fuel can gel on a diesel if its not cold enough. I was told to only use the heater is less than 20.
DMax BLACK '05 LS CC LB @ 100K miles, factory 2" lift, HID's
Banks Economind, IQ, Intake, SpeedBrake, Boost Tube, Monster Exhaust
Other AFE MP, Amsoil & Bypass, Ameriguard spray-in liner, Leer Cap, Bed Rack, Bug Guard, Inverter.
Crap Iron Cross Automotive Nerf Bars - NOT RECOMMENDED!!
Helpful Helm GM Service Manuals - like... 9000 pages!!
Rescue VHF Radio, Jotto Desk Laptop command center, Rescue Gear, Lotsa Flashy LED's, Shinny Decals
Haulin B&W Turn Over Ball & Companion, Firestone Ride-Rite Air Lift Bags, '14 Heartland Warrior Toy Hauler, (12000lb dry), Kayaks, Harley
DuraMac is offline
post #7 of 15 (permalink) Old 11-13-2009, 07:05 AM
03-GMC's Avatar
Thats probably my problem then. Weird thing is it doesnt cut my power until i drive home from work. So i will stop plugging it in and put my intake heater back in.
2003 GMC LB7 CC/SB
12.78 @ 105, 657HP
-Derek
03-GMC is offline
post #8 of 15 (permalink) Old 11-13-2009, 07:08 AM
DuraMac's Avatar
Incidentally, I have the full set of Helm service manuals for '05 which may be similar if I can look something up for you
DuraMac is offline
post #9 of 15 (permalink) Old 11-13-2009, 07:11 AM
03-GMC's Avatar
Well if you could tell me where the Fuel Temperature sensor is located just incase it is bad. I hope it isnt though i guess i will see if she throws another code when i get off work.
2003 GMC LB7 CC/SB
12.78 @ 105, 657HP
-Derek
03-GMC is offline
post #10 of 15 (permalink) Old 11-13-2009, 12:22 PM Thread Starter
delong_1's Avatar
all it was in my case was plugging it in when it wasnt cold enough to need it. if i didnt plug it in everything was fine.
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
