lb7 head removal???????? - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 04-25-2010, 06:10 PM Thread Starter
jax-d-max's Avatar
Who's removed lb7 heads? Is it easier to pull the motor or do them in the truck? 04 with an allison...
Crew Cab Long Bed, 12" Cognito with Deavers, 38x15.50 Interco STS's on 20x12 KMC Rockstars, ARB Lockers, 4:56's, Fresh LB7, ARP Studs, EFI Live w/DSP5, cheap intake, 5" MBRP, ect...
jax-d-max is offline
post #2 of 21 (permalink) Old 04-25-2010, 06:11 PM
Kroggs's Avatar
I belive lots have done them in the truck but anything you can get out of the way makes it easier......
2005 LLY Gmc 3500 CC/LB not bone stock I have a brake controller!!!
Thanks to Tyler @ www.meyerperformance.com
Thanks to Chad @ http://www.alligatorperformance.com/
http://www.facebook.com/group.php?gi...?id=1210592953
Originally Posted by MNDiesel View Post
I hate to derail, but how do you get a quote in your sig?
Like this^^^^^^^
Kroggs is offline
post #3 of 21 (permalink) Old 04-25-2010, 06:11 PM
Kroggs's Avatar
Also most doing them in truck can turn them around in 10-15 hours.....
Like this^^^^^^^
Kroggs is offline
post #4 of 21 (permalink) Old 04-25-2010, 06:18 PM Thread Starter
jax-d-max's Avatar
I got started on it today and it seems doing the turbo and all the pipes would have been easier and maybe faster to remove the motor...
post #5 of 21 (permalink) Old 04-25-2010, 06:20 PM
Kroggs's Avatar
Yep but then you gotta do more removing. Like I said more out of the way the easier it is
Like this^^^^^^^
Kroggs is offline
post #6 of 21 (permalink) Old 04-25-2010, 06:23 PM
duramax9878's Avatar
with that lift u may want to pull the motor
06 LBZ Dmax Toy Truck
07 LMM Dmax Tow Rig
duramax9878 is offline
post #7 of 21 (permalink) Old 04-25-2010, 06:25 PM
getting the heads off aint that bad in the truck but ur truck sits high as heck
07 LMM Dmax Tow Rig
post #8 of 21 (permalink) Old 04-25-2010, 06:38 PM Thread Starter
jax-d-max's Avatar
I have a truck/car lift I put 2x12's 0n for scaffolding so I can walk around the front. works out good. It's my first time tearing into this motor other than changing the injectors and it was a nightmare removing the bolts on the up pipes and down tube. Maybe it will be easier going back together.
post #9 of 21 (permalink) Old 04-25-2010, 06:43 PM
it took Freighttrain and i a decent amount of time to do it. use a big breaker bar on the studs, takes them off like butter. same for the hex head bolts on the covers and the heads themselves.
muddinredneck730 is offline
post #10 of 21 (permalink) Old 04-25-2010, 07:06 PM Thread Starter
jax-d-max's Avatar
I hope the new heads and studs will be worth it! No pain no gain I guess...
