| | eBay Motors #11 (permalink) | |
| Duramax Forum Supporter Join Date: Apr 2007 Location: Wyoming
| Quote:
Cracked injector or leaking ball/seat would show a bad balance rate because it would be injecting too much fuel into a certain cylinder...which would cause a bad balance rate as the ECM tries to compensate for a cylinder that is overpowering the others. If you look up in eSI (gm factory service manual that the dealers use), the diagnostic flow charts all point to a bad regulator, and say to replace it...I realize those arent always right, but every other LB7 ive had with these symptoms had a bad regulator.
__________________ 05 dmax/allison | |
| DuramaxForum Fanatic ![]() Join Date: Apr 2008
| Just so it is covered. 2003 LB7. Two sets of injectors replaced before 42K. 102K miles now with no rough idle, no smoke, no white haze. Nothing but a smoother running, quieter Dmax that pulls like crazy. I use a combo of Diesel Concentrate AND Cetane Booster from Amsoil in every tank. IMHO it is worth testing, most that have tested this combination have had great results. I have heard zero negative feedback from those that have used the combo according to the instructions. Anyone who would like to test it for themselves, let me know and I will get a couple of bottles of each sent so that you can decide for yourself whether they work as well as we claim.... Have a GREAT day and good luck with your issues.
__________________ |
| | eBay Motors #13 (permalink) |
| DuramaxForum n00b Join Date: Mar 2010
| Duratothemax, I agree with you with everything that has been happening. I really wish the FPR had fixed the problem. I guess we just need to figure out whats cause that surge at idle and dumping the extra fuel.... |
| | eBay Motors #14 (permalink) | |
| Quote:
Ben
| | eBay Motors #15 (permalink) |
| DF Sponsors ![]() | I still think it is your injectors...... Injectors are the only thing that could cause the white smoke, unless you have a coolant leak.
__________________ - Titus Vote Ron Paul for president 2012 Click here For, LB7 Injector Install Instructions |
| | eBay Motors #16 (permalink) |
| the white smoke was unburned fuel; thats what the smell was.
| | eBay Motors #17 (permalink) |
| Did the Injectors I did the injectors this weekend. took me saturday and sunday. job went well, Duratitus injector replacement post was very helpful. Once again the idling white smoke problem has been solved by changing injectors. I changed all 8. Not too bad of a job, truck is running amazing!!!... |
| | eBay Motors #18 (permalink) |
| DF Sponsors ![]() | Glad you got the problem fixed, and good to hear my injectors worked good for you! Congrats!
| | eBay Motors #19 (permalink) |
| im having very similar problems with my 02 lb7 ive had it for three months now,it has 147xxx and i noticed the injectors have been replaced once already,but the smoking problem with it stumps me,when its nice out and sunny it wont smoke at all but when its damp and rainy or snowy out itll smoke,no loss in power,no loss in mileage,doesnt idle rough and no injector knock...and its only been doing it for about a month since i have owned it, i drive it a half mile down the road and the light smoke clears right out ![]() thanks |
| | eBay Motors #20 (permalink) |
| so im having a similar problem... i have an 02 lb7 with 147,xxx and the injectors have been replaced .the smoke has got me stumped. it only really smokes when its snowing or raining (damp out) and when it does smoke it only smoke at idle and at drive for about a half mile down the road and itll clear out. i changed the fuel filter because that was real dirty. i have no loss in power what so ever no loss in mpg,its no louder than it was before it started smoking,no injector knock or abnormal sounds so i dont know..... |
