quadzilla trouble, truck wont start? - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 06-06-2010, 09:06 PM Thread Starter
03_dmaxhd's Avatar
went to change tunes today on my truck. plugged it in and as it was loading said error...turned the key off and unplugged it, when i went to try it again it said the tune loaded but there was an error and couldnt read the vin on my truck.. decided to leave it alone and just start the truck but it would not crank. checked the fuses and they were all good but the relay fuse next to the starter kept clickin every time tried to start.. any ideas, truck is currently stuck at a gas station. thanks for any help
2007 Crew Cab 4x4
-EFI from ATP on the way
-MBRP 4" Turbo back
03_dmaxhd is offline
post #2 of 10 (permalink) Old 06-06-2010, 09:12 PM
REW_388's Avatar
Wow I would be calling quadzilla customer service first thing in the morning if nobody has an answer for you on here... good luck!!!
RIG-2002 CC/SB 2500HD
SUSPENSION-Rancho 4 in. Lift -Bilstein Shocks -Tie Rod Sleeves -Moto Metal 957 wrapped in Toyo Open Country M/T 35x12.50R18- SSBC Slotted Rotors EXHAUST- Custom 5" with 6" Black Aussie Stacks TRANSMISSION -Built by Tim Hecker -GMax 5 Pac -Precision ML Converter -MikeL Pump Rub Wear Plate -Transfer Case Brace PERFORMANCE- 60% Over Injectors- PPE Dual Fueller- AFE Pro Dry S Stage 2 Intake -AirDog II -Banks BigHead Wategate- SDP Batmowheel- EFI with CTS Insight- ARP Headstuds- Banks Technicooler- 3.5" Turbo Inlet
If you're in the Midwest and need a great shop talk to Tim Hecker at Busted Knuckle Diesel... Only mechanic I trust my truck to.
REW_388 is offline
post #3 of 10 (permalink) Old 06-06-2010, 09:37 PM
what part of south texas?
15 3500 CCLB 4x4 LTZ
John Wayne is offline
post #4 of 10 (permalink) Old 06-06-2010, 10:16 PM Thread Starter
03_dmaxhd's Avatar
im in uvalde...and ya i called them and left a message, hoping its just the little relay and not a messed up ecm or somethin
2007 Crew Cab 4x4
-MBRP 4" Turbo back
post #5 of 10 (permalink) Old 06-06-2010, 10:41 PM
REW_388's Avatar
Well call them agin in the am cuz they suck at returning calls in a hurry... atleast in my experience
REW_388 is offline
post #6 of 10 (permalink) Old 07-01-2010, 01:10 PM
did u find out what the problem is?
05 GMC 2500
tiosterling is offline
post #7 of 10 (permalink) Old 07-01-2010, 06:10 PM Thread Starter
03_dmaxhd's Avatar
well kinda, never talked to any of them but went back later to the diagnostic option and then went to return truck to stock and it loaded....so i guess it had a glitch or somethin in the computer
2007 Crew Cab 4x4
-MBRP 4" Turbo back
post #8 of 10 (permalink) Old 07-01-2010, 06:24 PM
Silverado482's Avatar
Send a message via AIM to Silverado482
I'm having the same problem on 70Hp.. After playing around and dowloading another update sent right from Quad I'm still having issues and need to send my quad back.. Not looking forward to that!..
2013 LT LML Crew Cab
BugFlector II Hood Deflector, AVS Window Vents, Readylift Level Kit, Wheel Liners, Chevy Mudflaps, Bedrug Bed Liner, RBP 18" Wheels, Tonneau Cover, 295/70/18 Nitto Terra Grapplers, EFI Live Autocal Motorops Tuned, Caltrend Neoprene Seat Covers, Bilstein Steering Damper, Black out Bowties.. and more to come
www.alligatorperformance.com
http://www.rollinsmokediesel.com/
http://www.Madjacksynthetics.com/
Silverado482 is offline
post #9 of 10 (permalink) Old 07-01-2010, 07:10 PM
well at least you were able to get it out of the convenient store...
05 GMC 2500
post #10 of 10 (permalink) Old 07-01-2010, 07:11 PM
sagebrush assas's Avatar
mine has done that before..Make sure all powers are off when trying to load a tune..(radio,A.C., dome lights etc..) you can always go to the return to stock if that happens
2007.5 LMM
Quad 110HP
4" exhaust
Diesel Performance Parts & Products | Alligator Performance
Husker Diesel - 402-502-6961
Coming soon
Twins,trans. upgrade, lift pump
sagebrush assas is offline
