Gear ratio? - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 06-20-2010, 07:46 PM Thread Starter
Gear ratio?
Is there a way I can check my gear ratio without putting the truck up and rotating tires while counting driveshaft revolutions?
I come from Fords and I know they usually have an axle code on the door sticker and a tag on the rear diff to tell gear ratios. Does GM do something similar?
Thanks.
Bill
03 Chevy 2500 HD ECSB.
LS trim D-Max with the Allison.
Diablosport Predator on 85 Horsepower tune.
Smashed96gt is offline
post #2 of 8 (permalink) Old 06-20-2010, 08:00 PM
dmaxdave's Avatar
pretty sure all 3/4 and 1 ton duramax trucks are 3.73
dmaxdave is offline
post #3 of 8 (permalink) Old 06-20-2010, 08:37 PM
VAGITARIAN :)
daddysLBZ's Avatar
They ALL have the 3.73 gearset due to the Allison doing a real good job at spreading the torque evenly.You could get a 4.10 gearset in a special order chassis cab[claims one member here,but I dunno for sure].
FYI you can figure out any ratio by dividing the number of teeth on the pinion by number of teeth on the ring gear
2006 GMC 4x4 CC/SB/sle1/LBZ**312,000 miles!!** PPE HOT+2 225 TUNE beeeyotch:-)AutoMeter egt/boost Suncoast 5 trans w/1056TC!tsktsk,billet in/out shafts/MagHytec pan!!,M/A built T-Case,4 in.str8piped,5%tint all around......
2007 Chevrolet 4x4 cc\sb,lbz.......SOLD to blunova
Also, I speed and don't come to complete stops at stop signs.
''don't sweat the petty things,pet the sweaty things''
Click below/pictures of my junk!!
http://www.duramaxforum.com/forum/vb...do=hall&u=8415
daddysLBZ is offline
post #4 of 8 (permalink) Old 06-20-2010, 09:14 PM Thread Starter
Thanks guys.
I knew I could count teath and divide but thats smelly and potentially messy.
post #5 of 8 (permalink) Old 06-21-2010, 05:51 AM
mijdirtyjeep's Avatar
Originally Posted by Smashed96gt View Post
Thanks guys.
The easiest way to find out what gears you have in your truck, is to look in the glove box. You will see all the RPO codes there. Here is the gear/locker codes
G80 - Locking Rear Differential
GT4 - 3.73 Rear Axle Gear Ratio
GT5 - 4.10 Rear Axle Gear Ratio
I bet the farm you will find the G80/GT4 though
Jim
mijdirtyjeep is offline
post #6 of 8 (permalink) Old 06-21-2010, 08:56 AM
VAGITARIAN :)
daddysLBZ's Avatar
Thanks guys.
I hear that!
post #7 of 8 (permalink) Old 06-21-2010, 08:58 AM
Quicker Then Brian!
RedBowTies88's Avatar
:welcome.......
Beech - 05 LLY CC/SB 4x4
12.31@108.57 On stock turbo and fuel system
Thanks to,
Big Dipper, Efilive, Calvert, Precession Converters, Nick@Duramaxtuner, Eaton, Pureflow, and Falken
RedBowTies88 is offline
post #8 of 8 (permalink) Old 06-21-2010, 11:53 AM
VAGITARIAN :)
daddysLBZ's Avatar
.........................:rockin:rockin
