Old 05-13-2008, 12:33 PM   eBay Motors   #1 (permalink)
duramax03
Points: 77, Level: 1
Points: 77, Level: 1 Points: 77, Level: 1 Points: 77, Level: 1
Activity: 0%
water pump
my 03 duramax was leaking coolant from the weep hole. we are replacing the water pump, we talked to a few dealerships, and they all said that we needed to buy a GM water pump that had the pump and cover, but we already had a water pump from NAPA. do you need to replace both the water pump and the cover or is ok to just replace the pump?
duramax03 is offline   Reply With Quote
Old 05-13-2008, 08:44 PM   eBay Motors   #2 (permalink)
jaydawg
Points: 666, Level: 9
Points: 666, Level: 9 Points: 666, Level: 9 Points: 666, Level: 9
Activity: 10%
Activity: 10% Activity: 10% Activity: 10%
jaydawg's Avatar
Stick with OE, better to replace once, than save a few bucks and replace 3,4,5,etc. times. Be sure to replave o- rings for the pump and by pass hose(u move it when u replace pump)
jaydawg is offline   Reply With Quote
Old 05-14-2008, 08:26 AM   eBay Motors   #3 (permalink)
duradude6.6
Points: 692, Level: 9
Points: 692, Level: 9 Points: 692, Level: 9 Points: 692, Level: 9
Activity: 0%
duradude6.6's Avatar
Whats the difficulty level to change one of them?
duradude6.6 is offline   Reply With Quote
Old 05-14-2008, 10:52 AM   eBay Motors   #4 (permalink)
Hodawg
Points: 96, Level: 1
Points: 96, Level: 1 Points: 96, Level: 1 Points: 96, Level: 1
Activity: 0%
Hodawg's Avatar
Howdy folks,
I'm brand new to the diesel scene, just picked up an 01 2500 Dmax last week, so I don't have much to contribute yet concerning diesels. But on the water pump question I do have some expertise. I worked for 4 years in the R&D department of Eastern Industries, Inc. in Panama City, FL. They are the largest manufacturer of automotive aftermarket water pumps in the world. The quality of their water pumps is second to none, and in fact is superior to many of the O.E. pumps. On this particular pump (Eastern # 18-1601) all components are made to EXACTING O.E. specs (blueprints and specs provided to Eastern directly from GM) with the exception of the ball-roller design bearing and the bearing shaft seal. These two components are actually of a superior design to the O.E. versions. I no longer work for this company and have no investments with them, so I have no financial incentive for making this recommendation. But when it comes time to replace the water pump on my 01 Max, I will demand the Eastern Industry pump because I know personally the quality that they build into their water pumps.They are available through ACDelco and many other outlets. Check them out at www.eipumps.com.
Beers,
Ken
Proud owner of "Old Rattler"
2001 Chevy 2500 HD 4WD
and
Proud owner of the "Little Green Bastard"
'71 Triumph TR6
Manufacturing Engineer
Clawhammer Banjo Frailer
Hodawg is offline   Reply With Quote
Old 05-14-2008, 08:34 PM   eBay Motors   #5 (permalink)
jaydawg
Activity: 10%
jaydawg's Avatar
If you have time..it is about 5 on a scale of 1-10. just alot of stuff to remove. fan shroud, fan ,coolant, harmonic balancer,lh inner fender well, etc...
