Fuel Filter Change - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 07-18-2010, 05:53 PM Thread Starter
simon1239's Avatar
Fuel Filter Change
I am changing the fuel filter on my 2002 Duramax for the first time and am not sure what type of lube I can use on the o-rings? I went to Autozone and Advanced Auto and they looked at me like I was crazy when I asked for o-ring lube. If anyone can help that would be great.
2008 Chevrolet Silverado 2500HD 4X2 RCLB
3" Spindle Lift
Mamba M2 17X8
285/70/17 Nitto Terra Grappler
simon1239 is offline
post #2 of 6 (permalink) Old 07-18-2010, 06:08 PM
bhiland23's Avatar
Alot of people just rub alittle diesel fuel on it.
2003 GMC Sierra SLT CC/SB. Loaded interior, autometer gauges, ATS E-POWER, Ported fuel fitings, CP3 mod, Intake horn mode, PPE Boost valve, Rapid Flow intake, Straight piped with 6 inch tip, High idle, 20x8.5 KMC Black D-Backs with 275/55/20 Cooper Zeon ltz, Tinted windows, Step tubes, Bed rail caps with bed tubes, adding more all the time. Decked out with LEDs for the fire department. Saving for trans and a few more goodies.:rockin
bhiland23 is offline
post #3 of 6 (permalink) Old 07-18-2010, 06:12 PM
Administrator
jc1843's Avatar
I am surprised they did not send you to the drug store for KY gel!
Most anything will help-- I use a dab of wheel bearing grease in the O-Ring groove to help hold the O-Ring in place and a little on the top. This is to keep the O-Ring from rolling and coming out of the groove when you tighten the filter. Also a little in the center seal to help it slide over the nipple.
Some just use a little diesel fuel!
Not a good idea to fill the new filter with diesel-- you will send un-filtered fuel to the injector system!
jc1843 is offline
post #4 of 6 (permalink) Old 07-19-2010, 02:29 PM
DSTRBD's Avatar
Just rub a little diesel fuel on the o-rings, thats all you need.
DSTRBD is offline
post #5 of 6 (permalink) Old 07-19-2010, 03:29 PM
caberto's Avatar
I've used a little but of vaseline on the 0-ring... never had an issue.
- Albert
05 2500HD Duramax/Allison LLY, SB, CC, 4X4. EGR plate, finger stick, K&N Air Filter, Hypertech Max Energy, 285's.
www.imagesbyberto.com
caberto is offline
post #6 of 6 (permalink) Old 07-19-2010, 11:59 PM
Tow Master's Avatar
I use a little carburetor cleaner on the O ring. Slides right on!
Jason
Tow Master is offline
