common problems with 01-04 duramax with allison trans - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 08-05-2010, 09:07 PM Thread Starter
I'm looking at buying a 01-04 chevy 2500HD with duramax and allison transmission. Could anybody tell me what the common problems are with this LB7 motor? I plan on putting the banks performance mods like the big hoss bundle and want to know how reliable it will be?Any information is helpful. Thanks.
kmarrone1 is offline
post #2 of 12 (permalink) Old 08-05-2010, 09:20 PM
DuramaxForum Guru
kman2468's Avatar
Send a message via AIM to kman2468
LB7 have injector problems..but dont let that scare you. they are expensive and can go out whenever. but they are good motors...
but do not waste money on banks big hoss bundle..you could get more and better..for cheaper
Kyle
13 lml stock
sold 04.5 lly
kman2468 is offline
post #3 of 12 (permalink) Old 08-05-2010, 09:43 PM
battlegraduate09's Avatar
^^^ agreed. Some injectors last 150xxx miles and some are on their third set at that. I think you can do better than Banks, not bashing but some friends experience hasnt been wonderful to say the least. Also the edge juice w/a seem to cause problems in the lb7s at one point or another.
Josh
2006 CCSB 4x4 ZF6
battlegraduate09 is offline
post #4 of 12 (permalink) Old 08-05-2010, 09:54 PM
Stupid Has The Balls
Odyssey25013's Avatar
Just injectors. Run fuel additives and a good tune and they will last longer.....aka not banks
Ben
2006 LLZ LT3 EC/LB
"Going for Broke"
Some Expensive Parts, Good Times, Busted Knuckles, Long Nights and Fancy Gauges So I Can Watch While I Blow Things Up
Special Thanks To Ben Tyler at BT DieselWorks, LLC. For All The Help and Hard Work
Odyssey25013 is offline
post #5 of 12 (permalink) Old 08-06-2010, 11:12 AM Thread Starter
Is this the best motor and trans combo in the 2500 to get for under 30k or is the LLY with allison better? Im looking to aim for around 900ft/lbs of torque once i purschase then add upgrades, what do you suggest if not banks products?
post #6 of 12 (permalink) Old 08-06-2010, 12:39 PM
tigermack's Avatar
Send a message via AIM to tigermack
You need mods to your trans with any Duramax for that much torque.
03' EC LB7 2WD
T6 Rotella - Napa oil filter
Amsoil Torque-drive - Napa filter
PPE standard & boost valve | Bilstein 5100's | Prosport EGT & boost gauge w/ Autometer dual overhead pod | Pioneer Avic D3
tigermack is offline
post #7 of 12 (permalink) Old 08-06-2010, 01:25 PM
Had a 01 2500HD with the DMAX and Allison tranny, loved the truck, Had a K&N Drop in filter and a superchip Flashpaq and the truck ran awsome, great gas milage and more power than you needed. I pulled a 7900lb trailer with it and never had a problem in the hills. (I live in BC and we have a lot of mountains here)
The biggest problem was the injectors, before I bought it it had the injectors repalced at approx 50,000Kms, then again at around 100000Kms
When I traded it in the truck had 4 injectors that needed repalcement. Dealership said to repalce all and the cost was $5400.00 (I chanegd the fuel filter every second oil change also....)
I ended up trading the truck in for a new 2009 2500 with a DMAX (miss the fuel milage I was getting with the old one)
anyways overall they are great trucks and lots of power, just take it to the dealer to get the injectors tested before you buy it.
Later
kketsa is offline
post #8 of 12 (permalink) Old 08-06-2010, 01:29 PM
GeorgiaDuramax's Avatar
lb7 injectors are going to fail at some point, sooner or later. Mine lasted for 146,000 miles. Edge Juice w/ Attitudes are not the best programmers to run. Perhaps the newer versions on Edge products or better like PPE and EFI are the best. 01 dont have any emissions junk on them such as EGR or Cats. Mine doesnt so. You shouldnt have to do a PCV reroute on them either.
Tyler- 2001 LB7
Mods:EFI Live, GA Diesel Stg. 4, Garmon Custom Converter, AirDog II, EPR s464, EPR 5" intake, EPR 3" IC tube, EPR 3.5" Downpipe, RDL pedestal, Turbo Performace blanket, MBRP 4" exhaust, Silverline 6" Black Stainless stack, Autometer Cobalt boost/pyro, Modified 6" Fabtech, Fabtech traction bars, PPE sleeves, Cognito braces, Rancho shocks, 35" Mickey Thompson ATZ, 20" ProComp Extreme
472/941-Stock Charger
Thanks Harley, Phil @ Georgia Diesel, Trent Nell @ Extreme Prejudice Racing, Jason @ 4 Wheel Parts, Levi @ Turbo Performance Products
Georgia Diesel
706-356-2174
GeorgiaDuramax is offline
post #9 of 12 (permalink) Old 08-06-2010, 01:42 PM
diesel_tech1's Avatar
I have 155, 000 on mine did injectors at 138,000. runs great no problems with it, and i love my PPE Hot.
2001 GMC SLT 2500 HD Crew Cab short box 4X4 LB7
4" straight exhaust 285/75/r16 210,000miles
Auto Meter Carbon Fiber Ultra Lite Pyro, Boost Gauges
PPE Boost valve.
Turbo MP Mod PPE HOT+2
30% over injectors
Transgo and Red Eagle Clutches
merchant auto pump rub kit.
diesel_tech1 is offline
post #10 of 12 (permalink) Old 08-06-2010, 09:25 PM Thread Starter
what year duramax and allison trans combo is the best in anybody's opinion,without buying new?
