swing bearing or carrier bearing - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 08-08-2010, 06:37 AM Thread Starter
jappryor's Avatar
has anybody changed out there swing bearing on the drive shaft, if so what needs to be done got my drive shaft out cain't get the swing bearing off not sure if just rusted up or what needs be done to remove and put the new one on. thankls John
jappryor is offline
post #2 of 9 (permalink) Old 08-08-2010, 07:03 AM
Administrator
jc1843's Avatar
The bearing is a press-fit and you may need to take it to a machine shop and have it removed.
jc1843 is offline
post #3 of 9 (permalink) Old 08-08-2010, 07:23 AM Thread Starter
jappryor's Avatar
thanks for the info, didn't know it was pressed on figured i could change it my self. thank you
jappryor is offline
post #4 of 9 (permalink) Old 10-10-2010, 11:10 AM
bansheephreak's Avatar
did you have any problems after you got done with the job. I just did mine, and something is horribly wrong. Either that or a back brake. And did you have to wire brush the blue plastic coating on the spline shaft before it would slide easily with the other female end.
:rockin2006 silverado crew cab dually
midnight blue with tinted front windows to match rear, fiberglass running boards/steps, straight piped and a superchips programmer which I hate, bedliner, and b&w gooseneck, 33's w/ shock ext and wheel spacers:rockin
bansheephreak is offline
post #5 of 9 (permalink) Old 10-10-2010, 11:20 AM
Vrabel's Avatar
did you mark everything before you took it apart so it would go back together lined up the same?
R.I.P.
2001 Chevy CC/SB 4WD EFI Live DSP 5, LBZ Short Block, Cut LB7 Pistons,keyed crank and cam, balanced,LBZ Intake Runners with RDL Shorty Y-Bridge, EPR Twins, Big Dipper 40% overs, MBRP Cool Duals, LBZ CP3, ADII, BD Manifold, C2 Gauges, H2 Wheels, Cognito Sleeves and Braces, Hids-Hi-Low-Fogs.
Sheet Metal Workers Local #22
If it's not made in America, YOU paid too much!
Creatures of The Night Performance and ProFab Performance
Vrabel is offline
post #6 of 9 (permalink) Old 10-10-2010, 11:22 AM
maxxflip's Avatar
Get rid of all the rubber etc on the bearing so your just left with the race on the drivshaft, heat the race with a torch (propane works) and it will probably fall off...you might have to use a hammer and chisel to pound it off...or take it in and get it pressed off...
06 LBZ
LMM RIP 10/9/10
maxxflip is offline
post #7 of 9 (permalink) Old 10-10-2010, 11:23 AM
maxxflip's Avatar
U-joints could be out of phase....
06 LBZ
LMM RIP 10/9/10
maxxflip is offline
post #8 of 9 (permalink) Old 10-11-2010, 06:12 AM
Send a message via Yahoo to Chiefmorton
Check out page two I changed mine and listed how I did it with pics.
Strange feeling on Take off
2001 2500 HD LT Crew Cab Short Bed 4x4 Duramax
Turbo Mouthpiece Mod,
BFG 285-75-R16 On Stock Rims
Stock Exhaust With Muffler Delete
Chiefmorton is offline
post #9 of 9 (permalink) Old 10-11-2010, 08:45 AM Thread Starter
jappryor's Avatar
I marked the male and female shaft before i took it apart and took it to the dealer to get pressed off and new one pressed on, also changed all my u joints while it was off, i just greased up the spline before i put it back on.
jappryor is offline
