04 lb7 low oil pressure - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 08-08-2010, 09:26 PM Thread Starter
RustyWaterDogs's Avatar
The oil pressure gauge on my 04 LB7 is ready really low oil pressure. When it is started cold it reads 60 psi. At operating temp it reads about 30 psi at 70mph but will drop to ear 0 psi at idle and the DIC displays low oil pressure. I took it to my mechanic and his computer didn't get an oil pressure reading at all. He installed a new sending unit still no oil pressure tried a different cluster still no oil pressure. Manual oil pressure check shows oil pressure is at normal levels both cold and hot. Any ideas on the issue could it be the ecm or possibly a short in the system some where. Any Ideas would be greatly appreciated.
2008 Chevy 2500HD cc/sb. Duramax LMM, 6" Fabtech lift sittin' on 35's, Bilstein Reservoirs, custom paint, aftermarket nav, Edge Insight CTS, Airdog II 165,5" Straight piped, profab egr delete, EFILive DSP5 by Idaho Rob.
SOLD! 04 chevy 2500HD cc/sb. Duramax LB7, EFILiveDSp5 tuned by "Idaho Rob", Edge Insight CTS , K&N CAI, 4" exhaust, Airdog II 165, ppe boost valve, Nicktane with cat.
RustyWaterDogs is offline
post #2 of 9 (permalink) Old 08-11-2010, 09:16 PM
Help!!!!!!!!
I got almost the same scenario!! Lost oil pressure at a stop light, one night about a mile from my house. I Manually shifted and kept the RPMs up till I limped it home. In the morning I pulled my dip stick and the Level was all the way up the stick. Lots of Diesel. I scanned my truck and it said Open circuit, #7 injector or somthing like that. I replaced all my Odd injectors and everything was DISCO for 600 miles....(today) Driving back from lunch still Slightly paranoid, I looked at my oil pressure gauge while coasting down a hill and the NEEDLE WAS IN THE RED!!!!:gearjamin Checked my oil when I returned to work and no signs of diesel level was good. What the F
I already have a pillar gauge pod for Exhaust temp and Boost. I want a third for oil pressure. Does anyone know who sells a kit or who has what... Any suggestions would be appreciated. I pretty sure I have oil pressure but not sure haven't tested. Thanks Rick
ChevyHD001 is offline
post #3 of 9 (permalink) Old 08-11-2010, 09:17 PM
BTW 03 LB7 Banks exhaust k&n six gun tuner, big head waste gate, speed loader
post #4 of 9 (permalink) Old 08-12-2010, 09:47 AM
hi i am new hear, but i do have a 2004 lb7 duramax and i had low oil pressure, when it was cold outside i would start it and it would run about 60 psi oil press, but when it got warm after driving it a while it would barely even come up on the guage, what had happened is my injectors were leaking diesel into my crankcase causing the oil to get thin thus causing low oil pressure, i never got any codes or anything, i replaced the injectors and now it never gets low again. hope this helps
max-it-out is offline
post #5 of 9 (permalink) Old 08-12-2010, 08:26 PM
Banned
Yes it souds like your injectors took a crap and dumped fuel into your oil.
Why did you only replace the odd number injectors?
JoeSmith21 is offline
post #6 of 9 (permalink) Old 08-12-2010, 08:34 PM
DuramaxBuilder's Avatar
i lot of the times the gauge on your cluster is not always right they can be way off....coolant, oil, speedo, rpm,
Chris
01 Chevy 2500HD Dmax, 4x4, Reg. Cab Long Bed, SAS Dana 60 HP Kingpin. 10 inches , np 241 x case modded, 400,231 miles on it org. motor
03 Chevy 2500 HD CCLB. 16x10 Black Bead locks Stock with 271,000 miles
www.GetSomePerformance.com , Dont you think its time you got some!
DuramaxBuilder is offline
post #7 of 9 (permalink) Old 08-13-2010, 08:49 AM
i had all 8 replaced not just the ones that were leaking
2004 lb7 chevy, k@N intake, magnaflow exhaust, qaudzilla, bully dog monitor, ppe boost valve, 17 inch hummer wheels on bfg all terrains
post #8 of 9 (permalink) Old 08-13-2010, 09:07 AM
Banned
Yes, I was replying to the original poster.
post #9 of 9 (permalink) Old 08-13-2010, 03:22 PM Thread Starter
They tried a new gauge cluster and that didn't work so it's not the gauge. They can't even get a reading when they plug in there computer. No diesel in oil either. They are going to try the oil pressure regulator next. I truck has oil pressure it just won't read and display it. Thanks for the responses.
