Power steering gear box 2003 Silverado Diesel - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 08-16-2010, 06:26 PM Thread Starter
Completely stock. Need to change the PS gear box. Looks pretty straight forward....However, how do you get access to remove the fluid lines from the gear box.
I will be renting a Pitman puller.
If anyone can tell me the correct steps to remove and install it would be helpful. Wrench sizes, how I can avoid screing things up, etc.
Thanks, Jim
Rocker is offline
post #2 of 9 (permalink) Old 01-15-2011, 02:36 PM
Duramax HarleyHauler's Avatar
Did you ever find a write up on this job? Was it a hard job I see mine is leaking pretty good
2002 Crew Cab 4x4 Striaght Pipe New Injectors @ 140,000
Duramax HarleyHauler is offline
post #3 of 9 (permalink) Old 01-20-2011, 03:27 AM
mijdirtyjeep's Avatar
It is not all that hard of a job to do. Here is how I did mine "twice, Autozone gear boxes suck".
1st remove driverside inner fender well.
2nd remove both skid plates
3rd remove the drivers side CAC pipe
4th disconnect the pitman arm from the center link with a puller "leave pitman arm on gear box"
5th lock the steering wheel with a rope or tool, to keep it from turning "cloaking spring is not cheap"
6th remove both hoses from the top of the gear box
7th remove the bolts that hold the gear box to the frame
Now it is ready to fall out. I leave the Pitman arm attached to the gear box, seeing I am not going through all this work without getting a new one anyways. I will let the people who get the core for the gear box deal with getting it off
Jim
mijdirtyjeep is offline
post #4 of 9 (permalink) Old 01-20-2011, 08:28 AM
Thanks for the response. I see they make a seal kit for the gearbox also its only twenty some bucks maybe should try that first the gearbox is a little pricey
post #5 of 9 (permalink) Old 01-21-2011, 04:58 AM
I wish I would have just did replaced the seals in mine. I have tore mine out now a few times as the ones from NAPA,Advance all have a Sh*t tone of play in them. When I say play, I mean you can turn the wheel from 11:00 to almost 1:00 before the wheels move
IIRC I am on my 4th gear box now "not counting the factory" and finally got lucky as it has only minor slop in it "still more than the factory on had though".
Jim
post #6 of 9 (permalink) Old 01-21-2011, 09:18 AM
Snoman's Avatar
Buy a gear box from psc motorsports, they specialize in rebuilding them and i think they have a very good warranty with them. I know a couple guys tryed them and they said there trucks drive like new. I am going to get one soon. later, here is the link to them.
GM Steering Gears | Steering Gear and Components | GM | PSC Motorsports - performance power steering
2002 chevy Duramax ex. cab.
EFI live,
cold air intake,
turbo horn mod.
Snoman is offline
post #7 of 9 (permalink) Old 01-21-2011, 11:08 AM
XBoxLive: RenegadeDuramax
XtremeDMax's Avatar
Send a message via Yahoo to XtremeDMax
I'm not sure about ours... but I know on the older Chevys, you could tighten the gearbox.
2015 Silverado 2500HD CCSB LTZ Dmax
Originally Posted by TheStepChild View Post
You want your exhaust to be like a fart. You can't see it but you know the effects of it.
If you can see your fart you got problems. If you can see your exhaust ...
XtremeDMax is offline
post #8 of 9 (permalink) Old 01-22-2011, 03:10 AM
I have also read good things about PSC, and wish I would have heard about them when I first started replacing mine. If I get sick of the little bit of slop in mine that I have become used to, I am contacting them first.
Yes they still do, kind of a pain to get to but it can be done. With all the gear boxes I returned, I tried to fix it with tightening the Alen bolt first. You could make it so tighten it till it would bind the steering a little and the play was still there.
Jim
post #9 of 9 (permalink) Old 05-16-2011, 05:04 PM
When you do the seal kit do you have to take out the gearbox still? Sorry dumb question
2004 single cab lb7, with some new goodies
duramax92 is offline
